Camper/Toy Hauler Advice
RTTs, travel trailers, tents, crapper buckets
Re: Camper/Toy Hauler Advice
Post by RustyPW » Sun Nov 25, 2018 5:10 pm
My Outback wasn't like that. I could carry a full load.
Post by TwinStick » Mon Dec 10, 2018 1:00 pm
Maybe they improved over the years, IDK. Maybe Keystone Tail Gator was a shitty brand, IDK. I can tell you it was one of the first things I checked on our current camper & was glad to see it had actual angle iron supports. Also, not sure how much you guys know about water. I learned quite a bit while in the US Army & in my lifetime. Water filters are NOT water purifiers. 2 totally different things. 99% of Water filters do not filter out bacteria & virus's (which is what makes you sick). Most just filter out sediment, minerals & bad taste. 20-25 microns is the norm for particle size filters. I use a 5 micron sediment & a carbon filter for taste in my whole house water filters. It does affect water pressure. It helps keep the washing machine, dishwasher, shower head, faucets & ice maker from plugging up when they flush the hydrants & keeps the chlorine taste from being bad. To get to remove bacteria & virus's, you really need a 0.2 micron filter. Not practical at all in a whole house or camper system. Water pressure would be almost nil.
https://www.bigberkeywaterfilters.com/
https://www.youtube.com/watch?v=3F6Y3cDsSL8
The Pro's: They are portable, work on gravity, work with tap water, work with pond water, work with river water. They are purifiers.
The con's are: they take up counter space, cost more initially.....yet are cheaper long term. IMHO, the cross contamination issue addressed in the vid can be solved with a clean garbage bag & some vacuum line caps on the filter discharge nipples, like these https://www.summitracing.com/parts/trd- ... gJ9CfD_BwE .
Just putting this stuff out there for everyone to know. No one wants to get sick while enjoying the great outdoors. Algae & bacteria can also grow inside fresh water tanks & pipes of RV 's. We never drink the water from the camper, just do dishes with it. I also sanitize the system every spring with plain old bleach. No scents or dyes or concentrated formulas. Plain old bleach & water.
:cheers:
Post by TankerZak » Mon Dec 10, 2018 1:49 pm
I have two filters. One is sediment and second one is carbon, etc.
2016 Granite Crystal Metallic Power Wagon Laramie, graphics delete, debadged, Thuren front and rear coils, Thuren rear swaybar links, Thuren rear trackbar, Traxada rear 1 inch spacers, King 3.0 (Stage 4) front and 2.5 (Stage 3) rear shocks, Boogie front bump stops, Cooper STT Pro 37x13.50R17 on XD Machette 17x9 +18 wheels, DOR steering brace, Thuren King Steering Damper, Synergy Steering Kit, Thuren PW bumper, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 A.R.E. Spidersilk synthetic winch line, Zroadz Grill with slim 20 inch light bar, DDM Tuning LEDs/HIDs, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
Post by RustyPW » Mon Dec 10, 2018 5:28 pm
I use a 2 filter set-up in my motorhome. For drinking. I use bottled water.
Post by TankerZak » Mon Dec 10, 2018 6:59 pm
RustyPW wrote:I use a 2 filter set-up in my motorhome. For drinking. I use bottled water.
And that. Use bottled water for drinking.
2017PW
Post by 2017PW » Sun Feb 03, 2019 6:37 pm
So I’m curious if the OP ever bought a travel trailer? Any updates?
Udy2554
Post by Udy2554 » Sun Mar 03, 2019 4:49 pm
I have a Prine Time Fury 2910! 4000watt Cummins/Oman lp generator with remote prime/start, 600w solar, 78gal fed, GW40gal, BW40...
29’ living area(10’garage), 34 1/2’ total length!
11,000+Lb fully loaded, <1000lb TW! 12,0000 equal-I-zer WDH, Airlift 5000 bags, Daystar cradles w/remote!
Tows well for me at speed with RZR 900 and full water tank and 2 lp tanks!
Udy2554
Post by Udy2554 » Sun Mar 03, 2019 4:53 pm
jambbii
Post by jambbii » Thu Mar 14, 2019 10:48 pm
Yup! We got a Outdoors RV 27bhs. The finance guy is actually a member on here and has a 06 PW. I added on board air, Airlift 5000s and daystar cradles.
Post by RustyPW » Thu Mar 14, 2019 11:52 pm
Who was the member?
jambbii
Post by jambbii » Fri Mar 15, 2019 11:42 pm
Who was the member?
He didn't give me the details. Now that I think of it he may have had an 05. It was darker silver.
