2016 PW RESCUE UNIT
OffRoadRescue
2016 PW RESCUE UNIT
Post by OffRoadRescue » Sun Sep 29, 2019 11:48 am
:nopics: I have a 2016 power wagon with the front rear locker lights on fast flash which is a fault several people have this problem follow your wires on a 2016 behind the right front headlight is a plug with a bunch of yellow wires to your lockers I found after miles of troubleshooting that the plug was not fully seated in the block and the plug was not locked with the red button cleaned it plugged back in till it snaps and all problems are fine. Lockers work again :rant: hope this helps everybody else. :rant:
35" toyo's Custom lights, "YOU CAN GO FAST-I CAN GO ANYWHERE"
"YOU CAN GO FAST-I CAN GO ANYWHERE" :rockon:
Re: 2016 PW RESCUE UNIT
Post by Bill2014 » Mon Sep 30, 2019 7:43 am
Welcome to the Group ! :cheers:
Way to join - with a helpful tip :wink:
Post by RustyPW » Mon Sep 30, 2019 7:49 am
This isn't the first time someone has said that they found a plug not completely plugged in in the harness for the lockers.
:winchmob:
Post by Mule007 » Mon Sep 30, 2019 7:56 am
Additions: Frame mounted .188 DOM 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension leveling kit; Bully Dog GT Platinum SRT-10 A-pillar pod mount programmable performance chip, monitor, tuner; Linex Platinum black armor truck bed & lower rock panel armor coating; Range Rider cab high fiberglass canopy; 2” Linex brush guard light bar w/ 4-KC Rally 400 Series 4” Halogen off road lights; S&B CAI; Flowmaster American Thunder cat back dual exhaust to rear; Remote start; Hopkins Trailer Mate trailer brake controller; Bearcat Pro 68XL CB radio; Mopar black accent fender flares; power wagon winch kit & remote control; 60” Extreme High Lift; hand tools, tow straps, shackles, chains, cables, off road rigging, 4 wheel bad weather tire chains, spare water & 2 each extra 5 gallon narrow military jerry cans.
Post by Reloaderguy » Mon Sep 30, 2019 5:21 pm
Not all heroes wear capes.
