2018 PW Newbee
ArmageddonKaine
2018 PW Newbee
Post by ArmageddonKaine » Tue Nov 13, 2018 8:18 pm
Hey All Just purchased a new 2018 PW. Previous Ford F150 owner and have been for years. Fell in love with the PW and went out and bought one. I am having a few issues, although not sure they are issues or learning curves. I will post in tech forum once I get established. I'm gonna try to add a pic of my new machine but not sure it will work.....
2018 PW
Re: 2018 PW Newbee
Post by Low_Sky » Tue Nov 13, 2018 10:34 pm
Step one, download the owners manual.
Step two, read the manual.
Most of the answers to your questions are probably in there (you’re not the only one). Lots of stuff doesn’t work the same way as your Ferd.
Welcome to the party!
Re: 2018 PW Newbee
Post by Bill2014 » Tue Nov 13, 2018 11:33 pm
ArmageddonKaine
Re: 2018 PW Newbee
Post by ArmageddonKaine » Wed Nov 14, 2018 2:40 am
I haven't been able to find a manual that is PW specific anywhere. If you know a place to download one let me know. The manual I got with it is a generic RAM manual and doesn't seem to get into things that are specific only to the PW.
AlaskaTRX
Re: 2018 PW Newbee
Post by AlaskaTRX » Wed Nov 14, 2018 3:31 pm
Ditto. Stock manual is useless for 2017 Power Wagon owners, too.
Were there ever specific manuals???
Re: 2018 PW Newbee
Post by RustyPW » Wed Nov 14, 2018 4:02 pm
Welcome to the forum.
I have a printed Power Wagon manual for an '08. :mrgreen:
Russ NRA Benefactor Member
Re: 2018 PW Newbee
Post by Retired BLM Rig » Wed Nov 14, 2018 4:47 pm
X2
Lots of power wagon specific information on pages 455 through 492 in the 2017 manual.
2018 PW Newbee
Post by Low_Sky » Wed Nov 14, 2018 7:48 pm
The book you get with your new truck isn’t the manual. It’s an owners guide. The “quick start guide” if you will. The current manual is pushing six or seven hundred pages. If they printed it, it wouldn’t fit anywhere in the truck.
You can google it. “Ram 2500 owners manual”. They don’t make it hard to find.
Re: 2018 PW Newbee
Post by Mule007 » Wed Nov 14, 2018 8:28 pm
Welcome to the forum, Enjoy! 🌞👍
2005 Mineral Gray PW; #0666; frame mounted .188 wall 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension lift kit; Open Range All Terrain-35 x 12.5 x 17- MP3 10 ply,s; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; updated Bilstein 5100 Mono tube nitrogen gas shocks; new OEM radiator; updated U-joints; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Flowmaster American Thunder cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI; 60” Extreme High Lift jack& off road kit, bumper lift & tire lift kit; other rigging
ArmageddonKaine
Re: 2018 PW Newbee
Post by ArmageddonKaine » Wed Nov 14, 2018 8:31 pm
Ok..I'll check it out tomorrow. I hope it will give me pointers on the locking axles because as of present they still do not lock no matter what i do, they just flash but never seem to engage. I hope it will give some instruction on what is going on.
Chubbs
Re: 2018 PW Newbee
Post by Chubbs » Wed Nov 14, 2018 11:03 pm
Page 368 through 370 on the 2018 manual. Make sure you are below 3mph. Unless I am actually scrambling over something, I usually have to do some S turns to get the front to lock.
2018 Power Wagon
Re: 2018 PW Newbee
Post by Mule007 » Thu Nov 15, 2018 5:49 am
The 3 mph is a limiter, will not work above that speed, usually just flip the switch, turn the steering wheel, & creep forward. Helps if on dirt, gravel or surface where tires can slip a bit. Almost always works,,, If that doesn’t work for some reason try to search “lockers” thread,,,as it may be other issues,,,,good luck
Re: 2018 PW Newbee
Post by Retired BLM Rig » Thu Nov 15, 2018 10:00 am
I assume you know that currently the lockers only work in 4 Low. Without an owners manual you may have missed that little detail.
Chubbs
Re: 2018 PW Newbee
Post by Chubbs » Thu Nov 15, 2018 7:17 pm
By the way, here is the link to the manual:
https://www.mopar.com/ramtrucks/en-us/c ... arage=true
2018 Power Wagon
ArmageddonKaine
Re: 2018 PW Newbee
Post by ArmageddonKaine » Fri Nov 16, 2018 1:25 am
Thanks guys....I downloaded the manual. It pays to read. As some of u pointed out..It has to be in 4 low (did not know this). I put it in four low, moved forward about about 5km/h and BAM! Axels locked. Thanks so much. I love this truck.
Re: 2018 PW Newbee
Post by olyelr » Fri Nov 16, 2018 2:46 pm
Enjoy the new rig and welcome to pwr :cheers:
Re: 2018 PW Newbee
Post by KevinABQ » Mon Nov 19, 2018 12:49 pm
It doesn’t always lock up like that, though it should. Don’t wait until you are trying to climb the obstacle and need them to turn on the lockers. Do it when you still have some short distance before you need them.
Wagon9027
Re: 2018 PW Newbee
Post by Wagon9027 » Sun Nov 25, 2018 5:51 am
I called Mopar and they sent me a printed copy
