3rd Gen Smartbar Locker Bypass
Plug-N-Play Locker Bypass Kits
Moderator: myoung84
Re: 3rd Gen Smartbar Locker Bypass
Post by coder » Mon Feb 02, 2015 8:17 pm
Not real clear on the issue here but I will throw out a random thought, what about splicing in the existing factory connector as an option, would solve the issue?
06PW
Post by 06PW » Mon Feb 16, 2015 10:55 am
we had previously thought about a splice in version, but from what i gather it would have to be a unanimous decision among all 3rd gen guys. There wouldn't be any reason for ordering or looking for connectors for a handful of people especially if the minimum order is over 100.
2006 PW stocker, 35" Tires, lots of dents and scratches
Had everything from Land Rovers to Duece and a halfs
Post by coder » Thu Feb 19, 2015 7:27 pm
06PW wrote:we had previously thought about a splice in version, but from what i gather it would have to be a unanimous decision among all 3rd gen guys. There wouldn't be any reason for ordering or looking for connectors for a handful of people especially if the minimum order is over 100.
I need to fix my front locker, the locker actuator alone retails for $434, plus the labor for removing/reinstalling the front differential, which required a special dealer tool, I bet it's a $800 job.
Make me one, splice or no splice , and I will buy it. Why not just order them as needed from the factory at http://connectors.dcctools.com/home.htm , it cost a lot more, but add it to the overall cost and be done with it. That gets my vote.
06PW
Post by 06PW » Thu Feb 19, 2015 9:57 pm
coder wrote: Make me one, splice or no splice , and I will buy it. Why not just order them as needed from the factory at http://connectors.dcctools.com/home.htm , it cost a lot more, but add it to the overall cost and be done with it. That gets my vote.
sounds good to me
BigRed2007
Post by BigRed2007 » Fri Feb 27, 2015 9:21 am
I am pretty sure the issue with getting them from the factory is that they are not available from the factory. ... I may be mistaken though...
Flame Red 07 PW - BIG RED
KE0BZG
WQUY939
rhino
Post by rhino » Mon Mar 02, 2015 12:13 pm
Im on my second smart bar and its failing. Ill take a spliced one if youre willing make one.
Burud
Post by Burud » Thu Apr 16, 2015 4:50 pm
I can take a splice edition too, If you want to make one splice edition :)
Glenn5995
Post by Glenn5995 » Sun Jun 28, 2015 7:08 pm
Reading through these posts it appears myoung84 turned the locker bypass project over to CajunPW, but he is only running a list for 4Gs. Does anyone know if the 3G project was completed and if so, where do I go to purchase/get on a list? Thanks
BlkWgn
Post by BlkWgn » Mon Jun 29, 2015 9:38 am
Glenn5995 wrote:Reading through these posts it appears myoung84 turned the locker bypass project over to CajunPW, but he is only running a list for 4Gs. Does anyone know if the 3G project was completed and if so, where do I go to purchase/get on a list? Thanks
I have not been around much lately, but from what I understand the 3 Gen project has not gone anywhere
Glenn5995
Post by Glenn5995 » Mon Jun 29, 2015 9:26 pm
That is what I was afraid of. Reading through the posts, it sounds like myoung84 believed he had everything figured out out, but was finding it difficult to obtain a connector he needed to make the kit "plug and play". Lacking the connector it could be accomplished with some splicing. If that is correct and no kits are going to made, I would be interested in purchasing the schematic (assuming there is one) to try it my self. I need to get everything working and would prefer to use the original controls if possible, but it is beyond my electrical skills to figure out myself.
Glenn
lastmanalliance
Post by lastmanalliance » Sun Sep 13, 2015 2:20 pm
I was supposed to be the test truck for this kit. But unfortunately I could not contact myoung. I tried to contact him when I got back in country but no luck. I will be back in the states on November 4th so I will try again at that time.
Sent from my HTC6525LVW using Tapatalk
CajunPW
Post by CajunPW » Mon Apr 11, 2016 8:31 pm
Locked
