Painting Sliders - paint brand recommendations?
bamnq6
Model Year: 2019
Post by bamnq6 » Fri Oct 02, 2020 4:33 pm
Hello all-
I just ordered a set of White Knuckle Sliders with top plates for my 2020. I plan to use this truck so I chose to paint vs. powder coat. I want to touch up paint the gets scuffed off...
Any recommendations on paint brand and process? I've been a rattle can connoisseur in the past, but I've also painted an entire school bus with rustoleum and a roller...
I do live in Los Angeles, so some paint lines are restricted on availability. I might hit Tractor supply this weekend and check on options for catalyzed tractor paint.
Any tips and tricks would be appreciated :secret:
2020 Power Wagon
bamnq6
Model Year: 2019
Post by bamnq6 » Fri Oct 02, 2020 4:43 pm
Ugh, sorry all. I got several errors when posting this...
2020 Power Wagon
bamnq6
Model Year: 2019
Post by bamnq6 » Fri Oct 02, 2020 4:50 pm
2020 Power Wagon
bamnq6
Model Year: 2019
Post by bamnq6 » Fri Oct 02, 2020 5:22 pm
2020 Power Wagon
Re: Painting Sliders - paint brand recommendations?
Post by Bill2014 » Tue Oct 06, 2020 8:27 am
You don’t like the natural look? :lol:
5 years of nature looks like this:
Post by KevinABQ » Tue Oct 06, 2020 12:35 pm
I just use rustolium spray to touch them up as needed.
Post by Mule007 » Tue Oct 06, 2020 7:55 pm
So do we
Post by RustyPW » Tue Oct 06, 2020 9:23 pm
Bed liner in a rattle can.
Ducky's Dad
Post by Ducky's Dad » Tue Nov 17, 2020 1:57 pm
Since you are stuck in LA, your best choice for rattle can paint will be Krylon. Way better than Rust-O-Leum and dries a lot faster so easier to do the quick touchups. If you can find the color you want (satin black) in a lacquer rattle can, that is even better because nitrocellulose lacquer will chemically bond to itself with minimal prep for touchups. If you prefer to do a proper job with spray equipment, "import" some satin black enamel from Yuma. I know a guy who gets his in quarts and gallons from Sherwin Williams on the other side of the river. Also, San Diego County has different regulations than LA/Orange/Riverside counties, so you can find things there that are not available in LA. Lastly, there is still a 4,000 ft altitude exemption in So Cal, so you can often buy stuff in places like Big Bear that are not available down the hill.
Post by coder » Tue Dec 08, 2020 9:56 pm
I have used this on my sliders as touchup for my powdercoat it's good stuff, available at Pep Boys:
https://www.vhtpaint.com/specialty/vht- ... ther-paint
UTRay
Model Year: 2019
Post by UTRay » Mon Dec 14, 2020 8:52 pm
I used rustoleum farm and implement paint in low gloss black. I cut it 3 parts paint to one part paint thinner and added a harder. Shot it with a cheap harbor freight paint gun.
HeavyDuty
Post by HeavyDuty » Fri Jan 22, 2021 10:50 pm
Any brand name rust paint works awesome. I sanded mine and painted two coats of rust paint. It’ll last forever. Get the good rust proof paint
“ROCKY MOUNTAIN” TESTED
