LED fog Bulbs
LED fog Bulbs
Post by ramv » Tue Mar 10, 2020 11:46 pm
Bought a pair of these for $32
https://www.amazon.com/stores/node/1649 ... 6491572011
Initial assessment is wow. Obviously very white. Good spread out focus. I lowered them a bit so the lows were a bit higher (very easy with factory adjustment. )
Note the lows only help with very straight light. The highs have the same pattern but just further extended. They do overlap the fogs a lot more than just the lows but they do layer out a bit further.
I had considered some of the aftermarket replacement housings but on the Fog’s it felt like for the price it was worth giving a shot. I may lower forward or add a set of cubes with yellow filters if they reflect too much in the fog.
Oilbrnr
Re: LED fog Bulbs
Post by Oilbrnr » Wed Mar 11, 2020 12:32 am
Put some HID's in those projectors and really say wow. (oh holy shit)
'16 with '17 FWC
Re: LED fog Bulbs
Post by ramv » Wed Mar 11, 2020 10:39 pm
Sweet. Any good links?
Oilbrnr
Re: LED fog Bulbs
Post by Oilbrnr » Thu Mar 12, 2020 1:28 am
Headlight Revolution. 5000k or lower. Our projector housings are actually pretty decent. Nice sharp cutoff that you'll need to make sure you adjust accordingly. I also did HID for the highs, which work for where I drive in rural areas of AZ, but if you're situation is more on/off highs, their LED choice might be better. HIDs take a bit to come to full brightness.
Unless they prove to have a short life (which they are covered for as long as you own them by HR) it really is a dramatic upgrade. They've already paid off helping me see elk on the Interstate south of Flagstaff where I highly doubt I would have seen them in time with the OEM bulbs.
'16 with '17 FWC
Re: LED fog Bulbs
Post by RustyPW » Thu Mar 12, 2020 10:59 am
I just installed LED headlight bulbs and backup bulbs from HR the first of the year. :rockon: World of difference. :rockon:
If going to a HID headlight. Go with the 55 watt system.
https://headlightrevolution.com/vehicle ... dodge-ram/
