What did you do to your PW this week?
Mario75
Re: What did you do to your PW this week?
Post by Mario75 » Sat Jan 11, 2020 12:56 pm
TommyDuncan wrote:
Sat Jan 11, 2020 12:13 pm
Finally installed my locker bypass. Works great!
Figured out why my headlight was bouncing around...
...the bolt behind the grille was missing. The other side was finger loose. Now the lower mount is broken.
Removed the boot from my airbox(while I had it out to mount the box for the locker bypass). Trying to come up with a better way to suck air, not water. Sounds kinda good when I floor it!
Found another missing bolt on my slider.
I noticed my winch is leaking... no wait, my steering box. Actually it is oil all over everything from having the dealership do oil changes(strictly for warranty purposes).
I'm just happy to catch these small things before they become big things!
Really good catch for sure! Unfortunate that the stealerships don’t take pride in their work anymore.
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Jan 11, 2020 2:30 pm
Just seeing if these bulbs help brighten things up. Anybody else hate pulling off the plastic cowl and the grill just to change bulbs. Let's see...one of the middle grill clips busted...other half busted and I was being gentle. The passenger side white slider clip that you reach from the wheel well broke because it must have slid back down a little when I pulled the light out. Luckily there's enough clips and bolts that everything still holds together.ImageImage
:rockon: :chug:
Post by OffroadTreks » Sat Jan 11, 2020 2:36 pm
Put 39's on my truck
Post by RustyPW » Sat Jan 11, 2020 3:52 pm
That's the bulbs I replaced with the LEDs.
EasyDoesIt
Post by EasyDoesIt » Sat Jan 11, 2020 4:17 pm
What's the rubbing like? I've been wanting 40s but I don't want to deal with the fenders. Thinking these mini bfg 39s might be the way to go.
Steve
btsbarton
Model Year: 2019
Post by btsbarton » Sat Jan 11, 2020 9:04 pm
Got these heavy bois installed today. They work great as a step as well, just as I hoped. I will need to add some grip tape though so they aren’t slick when wet.
Post by OffroadTreks » Sun Jan 12, 2020 2:52 am
Steve
Hint, it's not the front that you need to be worried about, even though everyone seems to think that's where all the problems are. Don't need to move the axle, or any of that crap. If you have a high clearance, the trimming is about as much as a 37's, maybe a touch more. And the rubbing is the same.
It's the rear of the truck. Think about the movement of the rear axle at full stuff.
Post by RustyPW » Sun Jan 12, 2020 9:14 am
The Diablosport tuner really woke my PW up. :rockon: Feels like I'm driving another truck. Sent some logs to Hemifever to let him do some adjusting on the tune.
The tuner isn't the easiest thing to use tho. It has a learning curve to it.
Mario75
Post by Mario75 » Sun Jan 12, 2020 9:56 am
How many tunes from Hemifever do you get? And I’ve heard people saying they saw 2mpg increase on highway driving. Have you noticed any increases?
Post by RustyPW » Sun Jan 12, 2020 10:05 am
The number of tunes. I don't know. Never asked. The truck feels a lot strong on the 87 octane tune I have in now. Once the tank of gas is gone. I'll fill it up with 93 octane and try that tune.
Mario75
Post by Mario75 » Sun Jan 12, 2020 1:21 pm
Nice! How is the shifting? That’s what Is pushing me to tune the truck mostly.
Post by RustyPW » Sun Jan 12, 2020 2:03 pm
It's shifting better. The one condition I had was when I was slowly down to almost a stop, and then speed back up. The tranny seemed to hunt, and had a delay in the response to the gas pedal. That's all gone now. Doesn't feel like I have to mash the gas pedal all the time.
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Jan 13, 2020 1:53 pm
I think your 3rd gen is reflector type light fixture which works great with LED. My 4th gen is projector sport package fixture. It is better suited to bulbs that direct or light appears forward through the projector lense(halogen or HID). So, just doing the halogen upgrade bulb for now $55. HID upgrade from HLR is like $300.
:rockon: :chug:
Post by TankerZak » Mon Jan 13, 2020 6:12 pm
Synergy steering kit... 3 alignments, and centramatics.
Post by RustyPW » Mon Jan 13, 2020 6:20 pm
I was thinking of doing the projector swap. But it was a lot more money. :cash:
SeppW
Post by SeppW » Mon Jan 13, 2020 6:50 pm
Phillips X-Treme Vision is the prevailing halogen upgrade for the standard quad lamps. Not my recommendation, but recommended by people who live and breath automotive lighting. The bulbs have short life though.
Agree, major PITA to change bulbs.
Post by olyelr » Mon Jan 13, 2020 10:51 pm
Hows she drive now?!
smokewagon
Post by smokewagon » Wed Jan 15, 2020 10:38 pm
OffroadTreks wrote:Put 39's on my truck
Do you have a place you like in Boise to get tires mounted? I’m going to try the Kanati Trailhogs and need to get them mounted/balanced.
Post by OffroadTreks » Thu Jan 16, 2020 1:23 am
Discount Tire on W State St.
Post by OffroadTreks » Thu Jan 16, 2020 1:24 am
This also happened
Guess it's time for a new post or to update my build thread...
Mario75
Post by Mario75 » Thu Jan 16, 2020 6:13 am
This also happened
Drooling :drool: is that the carli diff guard?
smokewagon
Post by smokewagon » Thu Jan 16, 2020 8:39 am
Thanks
Post by RustyPW » Thu Jan 16, 2020 4:44 pm
Some day. I might get around to mounting my hydraulic cylinder for my steering. :roll:
Post by OffroadTreks » Fri Jan 17, 2020 3:55 pm
NOPE, That's from Maple Offroad, Neil is a great guy! I like to give business to those who support the hobby and community. This is why I'm big on Thuren, Dethloff and others.
Post by Reloaderguy » Fri Jan 17, 2020 8:34 pm
Steve
If you get a chance to flex the front can you get a picture of the clearance between the tire and the top of the front inner fender? My 40's just rub the underside of the airbox but I cut out the outer portion of the fender liner so my inner fenders are flat.
How do you like the hydro assist?
