What did you do to your PW this week?
Mario75
Post by Mario75 » Fri Jan 10, 2020 4:42 pm
This week I got around to installing some goodies from the wife. Also saved enough to have the bed liner sprayed.
1. Line-x commercial grade bed liner.
2. Pelican 9410L lantern with rapid charging base. These are the same lights we carry for firefighting operations. I wired an interruptor switch inline just in case the truck needs to sit for an extended period).
3. Hi-Lift jack extreme courtesy of the old lady. I mounted this using the 4xRac bumper mounts. I drilled 1/2” holes into the bed and used steel Wall anchors For large TVs on the other side. Worked awesome and I’ll probably use this from now on if I need to mount anything else in the bed.
4. Rigid tool box. This has all my recovery gear including winch remote, chains, master pull snatch blocks, shackles, gloves, ARB winch blanket, ARB tire deflator, ARB snatch strap, tree saver strap and some other odds and ends.
5. AMP hidden bed step second gift from the old lady. I guess I was good this year haha.
There’s more I want to do for the truck. But saving to buy a home is priority 1 right now. Eventually 35/12.5r17 tires will be the next purchase when my stock duratracs die.
What have you guys done for your trucks recently?
flattire
Re: What did you do to your PW this week?
Post by flattire » Fri Jan 10, 2020 5:43 pm
Filled it up with gas. So I can get my 13.3 MPG on the freeway. :excited:
But at $2.39 a gallon it's worth it. :cheers:
Mario75
Post by Mario75 » Fri Jan 10, 2020 5:49 pm
I guess filling up counts especially at 2.39 a gallon lol 😂
waldo
Post by waldo » Fri Jan 10, 2020 6:55 pm
Drove it and used 4wd and lockers for the last six days. :P
Post by RustyPW » Fri Jan 10, 2020 7:51 pm
Refinished my headlights. Installed my LED back up light bulbs.
Tomorrow, installing my LED headlight bulbs, Thuren swaybar links, and Diablosport tuner from Hemiifever. Was going to do it today, but it was raining hard at times.
btsbarton
Post by btsbarton » Fri Jan 10, 2020 8:23 pm
I’m surprised there wasn’t one of these threads before, I’ve seen them on most other auto forums.
Custom stainless transfer case shift knob I ordered came so I put that on.
I also got a pair of v-bar traction chains, and test fit them.
And last but not least I picked up my WKOR Sliders from the freight terminal today, and will install them tomorrow.
EasyDoesIt
Post by EasyDoesIt » Fri Jan 10, 2020 8:24 pm
Changed diff fluid after a 1000 mile break in on my 5.13s.
Wear pattern looked good to me.
SimonandSimonBeast
Post by SimonandSimonBeast » Fri Jan 10, 2020 10:29 pm
Nice. What size tires do you run with your 5.13s Easy?
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Fri Jan 10, 2020 10:54 pm
RustyPW wrote:Refinished my headlights. Installed my LED back up light bulbs.
The Thuren links make the stockers look like WTF. Not the sexiest upgrade, but just needs to be done. Good choice!
:rockon: :chug:
Post by RustyPW » Sat Jan 11, 2020 12:29 am
i have NAPA replacements on right now. You should see these wimps. :doh: I'll post pictures on my build thread when I'm done installing.
Mario75
Post by Mario75 » Sat Jan 11, 2020 12:31 am
That’s an amazing week if 6 out of 7 days you were in 4wd and using lockers. Had the Power Wagon in its natural habitat haha 😂
Mario75
Post by Mario75 » Sat Jan 11, 2020 12:33 am
Love that custom knob! I have been toying with the idea of extending my transfer case shifter and putting a ball. Hate how low mine sits.
Mario75
Post by Mario75 » Sat Jan 11, 2020 12:39 am
I’m wondering how much of a difference the LED headlight bulbs are over stock. I have a 17 and the lights are decent, just wish they had a little farther reach.
EasyDoesIt
Post by EasyDoesIt » Sat Jan 11, 2020 8:19 am
37" Cooper's probably another another 12-18months left on them. Then maybe 39s once I've seen a few guinea pigs work out the rub issues.
TommyG
Post by TommyG » Sat Jan 11, 2020 9:19 am
EBC solid rotors and Yellow Stuff Pads. What a difference.
flattire
Post by flattire » Sat Jan 11, 2020 9:37 am
The first 5 days were spent trying to get the front locker to work. :roll: :lol:
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Jan 11, 2020 10:09 am
flattire wrote:
Drove it and used 4wd and lockers for the last six days. Image
That’s an amazing week if 6 out of 7 days you were in 4wd and using lockers. Had the Power Wagon in its natural habitat haha Image
The first 5 days were spent trying to get the front locker to work. :roll: Image
Lol. Probably kicked in right as he was going back to pavement.
:rockon: :chug:
waldo
Post by waldo » Sat Jan 11, 2020 10:47 am
The front on the 19 works fine. I push the front lock button right as I start up the mountain where the road has a sharp left turn in it. Locks right up.
ghaugo
Post by ghaugo » Sat Jan 11, 2020 11:09 am
I finally fixed my driver headlight that was starting to look like an aquarium with all the condensation collecting inside. I finally broke down and took it out, found a leak on the top of the light housing and sealed it generously with silicone. Now the condensation is gone! Not sexy but it really made my day when I was able to get that nuisance taken care of.
Frame-welded Aluminess Rock Sliders(welded to frame), Cooper STT Pro 315/70/17, ARE Z-Series Topper, FilterMag GP101 (front and rear diffs), DeeZee Tailgate Assist, Skanda Kryptec Typhoon seat covers, Husky X-act Contour Mats, Purple Cranium Diff Covers Front and Rear, Dodge Offroad Steering Brace, K&N air filter, Thuren Track Bar, Thuren Short Arms, Thuren Overland Shocks, Airlifter Ultimate 5000 airbags, Daystar Cradles, High Country Customs Bumper, All AMSOIL fluids from Code4Synthetics.com
Post by RustyPW » Sat Jan 11, 2020 11:44 am
I will find out tonight.
Post by RustyPW » Sat Jan 11, 2020 11:46 am
I've been running that since 2012 with stainless lines. :rockon:
TommyDuncan
Post by TommyDuncan » Sat Jan 11, 2020 12:12 pm
Ate a taco!
TommyDuncan
Post by TommyDuncan » Sat Jan 11, 2020 12:13 pm
Finally installed my locker bypass. Works great!
Figured out why my headlight was bouncing around...
...the bolt behind the grille was missing. The other side was finger loose. Now the lower mount is broken.
Removed the boot from my airbox(while I had it out to mount the box for the locker bypass). Trying to come up with a better way to suck air, not water. Sounds kinda good when I floor it!
Found another missing bolt on my slider.
I noticed my winch is leaking... no wait, my steering box. Actually it is oil all over everything from having the dealership do oil changes(strictly for warranty purposes).
I'm just happy to catch these small things before they become big things!
TommyG
Post by TommyG » Sat Jan 11, 2020 12:50 pm
Stainless lines are on the punch list for 2020.
Mario75
Post by Mario75 » Sat Jan 11, 2020 12:52 pm
I’m definitely going to replace the brakes with EBC when they wear out.
