Can I just buy power wagon axles
Posted: Mon Oct 21, 2019 3:00 pm
by Thatdodgeguy
So I wrecked my 2010 pw I miss it but not the mpg. Got a2016 Cummins. Can I just buy some pw axles I know they started using the 11.5 & always used the 9.25 and other than maybe figuring out how to control them right which could be done, don’t they operate as a torsen limited slip when unlocked anyway? That would get me gears and lockers easy. Just no winch yet, and no sway bar? Still turn my head like a kid at every power wagon I see tho!!! I genuinely miss mine like a family member but hey 120 mph on the interstate wasn’t a good idea in that thing & I drive like an old man now. No one else was involved in the wreck but me. I had the governor turned off wish now I hadn’t done that. But hey I get 18 mpg now easy on 35s
Re: Can I just buy power wagon axles
Posted: Thu Oct 24, 2019 1:28 am
by HammerTime
If the axels are the same, just get lockers for your rig, you don't need to get Power Wagon axles. While you're in there get lower gears...:)
Posted: Thu Nov 07, 2019 4:15 pm
Yea. You’d mostly likely be better of just regearing your current axles and adding lockers.
Posted: Fri Nov 08, 2019 9:00 am
by Bill2014
Regarding re-gearing:
Keep in mind that the optimal gear ratios in our gassers are different from the optimal gears in your CTD. 4.10:1 would be low for the CTD and 5.13:1 would be low for the 6.4's.
:cheers:
:popcorn:
