2016 MDS Disabler
2016 MDS Disabler
Does anybody know if Range Technologies has anything in the works for an MDS disabler for the 2016 6.4L hemi?
2011 and 2016 Power Wagons
Re: 2016 MDS Disabler
Use the Tow/Haul button if you really want to keep the MDS off... That will turn the trans into a 5 speed suck a little more gas for you.
Another way is to just manually set your gear to 6th. Should help your MPG by .5mpg over tow/haul
- stamm20
Contact Greene racing and get a tuner and have him build you a tune. He's one of the best modern Mopar tuners
Sent from my Pixel using Tapatalk
That feels extreme for such a simple issue that already has multiple free solutions
But none-the-less, that is a solution for the OP
You can also turn it off with the Diablo piggyback computer. its about $500 and has some performance tunes as well
