WK Sliders - To diamond plate or not?
FLtoCOTransplant
Post by FLtoCOTransplant » Fri May 03, 2019 6:38 pm
For those that have the WK sliders- How stable are they when you use them as a step to get into the truck? Can kids and grandparents easily use them as steps? Also how are they when they get wet or muddy?
Since they are round I am concerned that the kids and grandparents will slip when they use them. If I diamond plate them I would think the flat platform would provide better support (though from the videos I have seen it is not like they stick out all that far). Few on here seem to put the plate on so it may not be that big of a deal.
Thanks for the info trying to make some long lead time purchases while I wait for delivery.
Re: WK Sliders - To diamond plate or not?
Post by olyelr » Fri May 03, 2019 11:26 pm
They work for me (and my wife and kids), but honestly as a step they are not very good. They hardly protrude enough to use much more than the outer tube edge. So close to the body that I noticed I have been scuffing the hell out of the rocker panel with my feet over the last few years. I have them with no plate and they are powdercoated... slippery as hell in just about all scenarios. I wouldnt think adding the plate would be much better though... maybe.
I would still get them again given my circumstance. But they are not much of a step. I would certainly not let my grandma try to get up on them.
Post by KevinABQ » Sat May 04, 2019 1:43 am
The diamond plate helps. You might want to add 3M anti-skid tape etc.
The diamond plate also somewhat protects the doors against junk kicked up by the wheels. Somewhat.
EasyDoesIt
Post by EasyDoesIt » Sat May 04, 2019 7:31 am
With the door open, what's the distance from the cab to the outer edge of the outer tube?
For extra traction, swing by your local skate shop and grabs some grip tape for $10-$20. 🤘
Post by TankerZak » Sat May 04, 2019 9:34 am
I have just the tube. Works perfect. I did use some rubberized grip tape that looks nice and has stayed in place for years. Wife doesn't complain... and she complains about everything. If your super concerned get the plate... I didn't want the extra weight or a ledge for mud and ice to collect ontop of.
Post by FordyceCreekTrail » Sat May 04, 2019 11:14 am
Honestly I think they work perfectly as a step. One exception, if they are wet.
Post by Bill2014 » Sat May 04, 2019 4:42 pm
They were slick for sure when they were new. wife, kids, and grandkids used to slip on them every time. Now that they are half brown with rust, they're not slippery at all - so I will leave them like that! I suspect the top plate would be just about as slippery when it's new and wet. :cheers:
I'm tall enough that I hop in without even touching them...
Post by ramv » Sun May 05, 2019 10:54 am
I didn't want the diamond plate in the northern climate as running boards collect ice/mud really bad. They worked great there. Now that I am in Houston, I would have got the diamond plate as I have a lot of different clients etc. in and out of my truck. They work great for me personally though, but I'm 6'2"...
m25443
Post by m25443 » Mon May 06, 2019 12:50 am
I have the full length diamond plate and prefer it. You can unbolt the diamond plate of you decide to take it off. Or you can get partial length diamond plate.
The thing that I found most useful as a step is to have them made 1"wider. Then they really work well as a step.
So, I have the 1" extra width with full diamond plate and after a week in Moab, if I had to buy another set, I'd buy the exact same way.
m25443
Post by m25443 » Mon May 06, 2019 1:10 am
XPLSV
Post by XPLSV » Mon May 06, 2019 4:37 am
I have the diamond plate on mine and put the 3M anti-skid tape along the length. They are certainly not as easy to use as a step as all of the typical non-rockslider steps out there, but those certainly don't serve the same purpose of protection. I'm glad I added the plate and the tape.
_________________
2017 Power Wagon
Post by olyelr » Mon May 06, 2019 6:08 pm
Like I said, they work just fine as steps for my use and family situation. But if you think they are gonna be anything remotely close to an amp step or a typical nerf bar type step then you have another thing coming. And if you think grandma is gonna safely hop up in there (wet or not) then your grandma is in much better shape then mine!
Just snagged this pic of mine, looking almost straight down on them. With typical shoes, your lucky to get the toes over the outer edge maybe a few inches at most. And getting in isnt too bad for scraping up the body (just use toes on outer edge), but getting out I have been scraping up the body with my heals.
Good enough step for me, but for you or grandma.... you decide!
Post by PWJouster » Tue May 07, 2019 7:41 am
ill be going full diamond plate, and adding an extra inch of width front to back.
Oilbrnr
Post by Oilbrnr » Tue May 07, 2019 1:49 pm
I've had mine for over two years now, and I did order them with the plate. Works great as a step IMHO and do keep rocks down from coming up on the rockers. No complaints from passengers getting in or out.
I put the 3M tape on the sliders on my Lexus, and 5 years later are starting to look pretty ratty. I'm glad I didn't do down that route with the WK's. You do need to pay some attention when wet, but much less than a bare tube.
'16 with '17 FWC
NovA ProspekT
Post by NovA ProspekT » Sat May 11, 2019 7:58 am
I have the WK sliders with the diamond plate on top, after 3+ years of year-round use I'd order it again. It works very well as a step, and prevents ones foot from potentially slipping and getting caught between the tubes. The diamond plate is actually quite "grippy", and has worked suprisingly well even during the winter. They are also just bolted down to small tabs on the tubular rails, so they can be removed if neccessary.
Lazarus
Post by Lazarus » Mon May 13, 2019 10:54 pm
Can you post a pic of yours? I’d like to see what they look like with the inch added on before I order mine.
FLtoCOTransplant
Post by FLtoCOTransplant » Tue May 14, 2019 2:44 pm
Thanks everyone for the input and perspective. I didn’t know adding an inch was an option. Do they roll the edge for safety or is it just a hard cut edge? I too am interested in pictures for this option.
Since the diamond plate is removable, that is the way I am leaning. Easier to take off than to add it after install.
Regarding traction I was thinking I could apply some roll on bed liner to the top plate as a “grip” enhancement.
Post by olyelr » Tue May 14, 2019 8:54 pm
The outer edge of them is the round dom tubing.
Post by KevinABQ » Tue May 14, 2019 10:05 pm
Unless you are very short that isn’t where you put your foot. Your foot touches the outer edge of the plate, then you rotate the foot to flat on the plate as you get into the truck.
Post by olyelr » Wed May 15, 2019 12:34 am
Yes, I have a set, Im aware. I was just referring to his question about the outer edge being square or not.
Now that I reread it, Im not exactly sure what his question even was about. Maybe the diamond plate?
FLtoCOTransplant
Post by FLtoCOTransplant » Wed May 15, 2019 12:40 am
Yes the diamond plate edge. Wasn’t sure if the extra inch was an overhang or just a wider plate. That picture is helpful.
Post by KevinABQ » Wed May 15, 2019 2:57 am
I’ve just got the standard diamond plate. Didn’t know there were options. Not sure I’d have taken it, as that puts the truck weight on the small SS screws that fasten the plate to the slider. This seems likely to end badly.
It it’s pushing the DOM tube out that wouldn’t be so bad, but it still increases the width of the truck by 2 inches.
m25443
Post by m25443 » Wed May 15, 2019 7:14 pm
The entire slider is 1" wider (if you order the wider width), including the diamond plate. The outer edge is the same either way: Round tube with the diamond plate sitting on top. I just got back from a week at Moab and got them scraped up, but a quick bit of rust converter or black paint and they will be back to new condition. They would have gotten scraped up even if they were the standard width. I think they probably offer better protection against door dings in the parking lot!!!
Call WKOR and they can give you all the details.
Post by KevinABQ » Wed May 15, 2019 9:36 pm
I scraped the hell out of the bottom and lower outer edges without needing them to be wider. But an interesting option I guess I missed.
Post by Will » Thu May 16, 2019 8:42 pm
Aren't these labeled and sold as sliders? Haven't seen them advertised as steps...
