Moved My Winch Plug Inside
Been meaning to do this since I read NOOB's build thread when I joined here. I live in the Northeast and am always cleaning dirt/corrosion out of the plug.
Factory plug next to the new wire and sheath:
Completed new harness: New plug mounted (Yes, I know my interior is filthy. I need to give the pig a bath.)
Re: Moved My Winch Plug Inside
Forgot what mine looks like, went wireless years ago and siliconed that plug solid. Haha
vie ... =13&t=2333
vie ... =13&t=2333
- Punishher7
This is a great idea
I got the Warn Wireless remote. Add a lanyard and now you can run the winch and drag the cable. Use it in cab or out.
It's on my list of things to buy. Wanted the plug out of the road salt and grime. Having the controller dummy corded to me while rigging a recovery would be just about ideal.FordyceCreekTrail wrote: ↑Sat Mar 02, 2019 4:51 pmI got the Warn Wireless remote. Add a lanyard and now you can run the winch and drag the cable. Use it in cab or out.
With the wireless remote and unit stays plugged into the receptical, so it stays protected.
You can keep the wireless module attached to the winch plug at all times? I was concerned with how long the module would last, but I was about to silicone that thing down
I have the one that the receiver had about a 10' cord and mounted it by the air filter. 100% silicone the plug and plug it in and forget it. Been years and no issues on mine.PWJouster wrote:You can keep the wireless module attached to the winch plug at all times? I was concerned with how long the module would last, but I was about to silicone that thing down
vie ... =13&t=2333
Yes, you can keep the receiver plugged in. It has a carabiner clip to hold it on if it comes un-plugged. Only happened once to me. I never used the wire controller as the wireless is so much easier.
