Technically not two Power Wagons but new pulling old. Old has 50:1 Crawl ratio, lockers, no nannies, and beadlocks. It's seen a rock or two.
2016 and 2001
2016 and 2001
Re: 2016 and 2001
I feel like i grew up watching your 2nd gen build on pavementsucks... still rocking it apparently?! Wish i could say the same.
Didnt air the bags up?!
Re: 2016 and 2001
They are at 50 PSI! Tires are at 60. should have seen it at 5 psi and 30 psi in the tires. probably 200 LB of spares in the bed, plus spare leaf springs on the tongue. Normally I use my WD hitch but guess they lost that at work.
I'll take it up to 65 psi tomorrow.
Re: 2016 and 2001
Yea, the more i look at it the back is about where it shiuld be. The front is just completely unloaded. Bags dont fix that. WD hitch for the win!
Re: 2016 and 2001
Looks better with 80 psi in the bags, and not having the front tire on the sidewalk.
