Intermediate Steering Shaft/Upper Steering Coupler Question
Posted: Thu Jan 10, 2019 11:32 am
by NickTF
Look at the picture below from the steering shaft of my 2015 PW. It would appear that if I remove the rubber boot clip and push the boot upward I will find some kind of telescoping joint correct? Otherwise, why have the boot there and splines. This shaft is quite noisy when I turn wheel back and forth short turns with motor off and I suspect the noise is coming from the location where the telescoping area is of this shaft. I believe this is the source of a clunking and popping i've been chassing. My plan is to apply liberal amounts of grease to the splines of this shaft and work the telescoping in and out repeatedly. I searched and found accounts in other forums where folks had done similar to eliminate the same sound I been chasing for a while.
I've already installed the EMF bushings in the pin area where the coupling joins the steering column. Before I installed them the noise was present and it has not changed after installing the bushings. For what its worth the pins were contacting the sides and quite sloppy before install of the bushings but again, did not appear to be the source of my clunking/popping.
Re: Intermediate Steering Shaft/Upper Steering Coupler Question
Posted: Thu Jan 10, 2019 2:42 pm
by Colibri
Yes, take that apart and grease it. I had to do that on mine as well. Chasing down a little clunk in the Steering.
Posted: Thu Jan 10, 2019 4:24 pm
by Reloaderguy
Tell your wife your wife you need hydro and a truss then quietly fix the problem with $10 worth of grease after.
Posted: Thu Jan 10, 2019 4:32 pm
by NickTF
:excited: :excited: :excited:
Posted: Thu Jan 10, 2019 7:52 pm
:rofl:
Posted: Thu Jan 10, 2019 8:29 pm
by NickTF
The shaft has a wiper seal that is super tight to splines and makes getting any real amount of grease in all but impossible. That said I applied, extended/compressed shaft, wiped grease which collected on seal back on splines, repeated this process about 50 times. Doesn’t appear to have fixed anything the noise is still there. Shaft u joint seemed tight and I noticed nothing obviously wrong with the shaft. Maybe the shaft is bad but not in an obvious way who knows.
Posted: Thu Jan 10, 2019 10:43 pm
by Colibri
You can drill and tap for a zerk if you’re feeling ambitious
Posted: Fri Jan 11, 2019 12:10 am
by Retired BLM Rig
If you're feeling less ambitious you can try this. It's not cheap but it's one of the best aerosol lubricants I've ever used. Penetrates with a thin solvent propellant that evaporates quickly and leaves behind a high pressure lubricant that won't run off and lasts a longtime.
Posted: Fri Jan 11, 2019 9:05 am
by NickTF
Thanks, I may give that a shot!
Posted: Fri Jan 11, 2019 2:55 pm
by Reloaderguy
Those guys must be huge Wutang fans.
Posted: Mon Jan 21, 2019 9:30 am
by NickTF
Wutang was out on tour so I ordered a new upper intermediate shaft. My GM buddy who's dealt with all the bad GM intermediate shafts by either replacing or filling them with grease drove the truck and felt pretty confident it was the upper shaft. Time will tell. If this fixes the issue but the problem comes back in another 50k or so i'll probably go the route of tapping in a zerk and filling the cavity behind the telescoping part with grease before replacing again. I'll report back when I swap the new upper shaft in.
Upper intermediate shaft part number: 55351302AL
Posted: Wed Jan 30, 2019 1:51 pm
by NickTF
Welp the new upper steering shaft didn't fix a thing. I also removed the lower shaft entirely and checked the u-joints. Just as tight as could be.
Worth noting that I grabbed the input of the steering box with both shafts removed to check play. I could move the input up and down maybe 1/32" to possibly as much as 1/16" of an inch and verified that the slop in the steering shafts appeared to be coming from this movement. My steering could not be tighter and doesn't wonder at all so i'm doubting the play I noted is abnormal...... No in and out play in the steering box input.
Posted: Wed Jan 30, 2019 8:48 pm
by Reloaderguy
Did you follow the service manual and check your ball joints?
Posted: Thu Jan 31, 2019 1:04 pm
by NickTF
I've not yet but will possibly this weekend. Wow, 0.090" combined is not a whole lot of movement before considered bad..... :shock:
