I need the torque value needed for the 18mm pinch nut which tightens the adjusting collar of the tie rod.
Merry Christmas!
Tie Rod Pinch Nut Torque - 2015 PW???
Re: Tie Rod Pinch Nut Torque - 2015 PW???
Any idea on the bolt diameter or grade? Damnit man this is the Internet. “Alexa, what should I torque the pinch bolt to in order to make my truck not sound like a toaster when it hits a bump....”
I carry the 10,000 page FSM PDF on my phone. Even without cell coverage or Alexa I can access everything I need to know for my truck. Fully searchable with hot links. It also covers PW specific info.
Yours is only $17 for 10,000+ pages. I highly recommend it for finding answers to questions like this. Guaranteed to make you smarter than the average dealer tech.
https://www.ebay.com/itm/Dodge-Ram-2500 ... rk:40:pf:0
That's awesome I'll pic this up asap so I can stop with these questions on the web!
Its 45 ft. lbs. on 05-09 I would bet the 15 similar if not the same
55 ft-lbs (tie rod end adjuster clamp). I bought manual as suggested above.
