New Shoes
ramv
New Shoes
Post by ramv » Sun Oct 21, 2018 6:56 pm
Sorry, not installed. But I am excited. Plus wheels are rated at 3650 lbs and tires are 3640 lbs which gives me 900 lb additional rear axle over the 3195 lb BFGs. (I know door tag stuff but let's be honest more capacity more better.)
35" Toyo MTs on AEV 17x8.5" wheels (Katla)
These will be my summer tires, I will run a similar size (BFG/GY/Nitto) with a 3 peak mountain on stock rims for winter.
Punishher7
Re: New Shoes
Post by Punishher7 » Sun Oct 21, 2018 8:43 pm
Looks great. I have the same wheel/tire combo.Image
Re: New Shoes
Post by TankerZak » Sun Oct 21, 2018 11:25 pm
Your axle is still only 6200. That's your hard limit. So tires and wheels only need to be rated to 3100.
Re: New Shoes
Post by olyelr » Mon Oct 22, 2018 12:31 am
JEEEZUZ get them on already!
Re: New Shoes
Post by KevinABQ » Mon Oct 22, 2018 12:58 am
Looks cool. At $240 each and +27mm offset I'd like to hear how they work for you.
ramv
Re: New Shoes
Post by ramv » Mon Oct 22, 2018 1:08 am
So an 11.5” AAM is only 6200lb? Did they downgrade the housing and bearings for the PW or did they downgrade the Rating for the axle due to stock tires/springs ? Which seems more likely? Part numbers should help. But it’s a stupid big heavy axle if that’s the max it can handle. A 950 AAm will handle that weight and factory torque ratings.
A Dana 70 is good to over 10klb and this is way more axle.
Re: New Shoes
Post by Bill2014 » Mon Oct 22, 2018 8:48 am
As Engineers, we always apply a healthy safety factor! :poke:
BoldAdventure
Re: New Shoes
Post by BoldAdventure » Mon Oct 22, 2018 9:54 am
It's not downgraded. If you look at the sheets, the PW rear axle has more carrying capacity, by 200lbs. Our front has less. Those are the same numbers on the Diesel and standard 2500 with both 5.7 & 6.4 engines.
Re: New Shoes
Post by TankerZak » Mon Oct 22, 2018 10:27 am
Ayup. It's an upgrade. Your truck can still carry a shitton but the axle is rated for 6200 but the ass end only weighs like 3500... so thats like 3700 in payload, etc.
Re: New Shoes
Post by Bill2014 » Mon Oct 22, 2018 11:45 am
From the literature for the Power Wagon model verbatim:
Gross Axle Wt Rating - Front(lbs): 4700
Gross Axle Wt Rating - Rear(lbs): 6200
Axle Capacity - Front(lbs): 5250
Axle Capacity - Rear(lbs): 6010
...the front rating is lower than the capacity...
ramv
Re: New Shoes
Post by ramv » Tue Oct 23, 2018 12:44 am
Got it. What about 3500 SRW? Same axle, different mounts.
Seriously, these are pathetically low ratings for this axle. I have Dana 70s that are way smaller/lighter with 10klb GAWR. My 1050 AAM Chevy was 6084 lb as that was the stock 245/75R16. (Same axle in the 3500 got a 6830 lb rating as it had 265/75R16E)
With 1,200 lb of tongue weight from the Lance 1985, 1300 lb of Can Am, 300 lb of deck, tools, parts, passengers, I don't want to overload the rear tires. The BFGs were fine this year, but I only did a few a short trips with limited highway.
ramv
Re: New Shoes
Post by ramv » Tue Oct 23, 2018 12:49 am
Wouldn't that be 2,700 lb? Which is F150 aka Visteon 975, payload?
ramv
Re: New Shoes
Post by ramv » Tue Oct 23, 2018 12:50 am
Sharp.
I am jealous on your lack of chrome
Punishher7
Re: New Shoes
Post by Punishher7 » Tue Oct 23, 2018 1:18 am
Sharp.
Thanks. I’m actually a big fan of the PW in Laramie trim and wish they still offered it. I generally buy new and the new “theme” was all that was offered, aside from the tradesman, when I finally got my PW. Had they still offered the Laramie I might have gone that route honestly. You have a beautiful truck man!
Re: New Shoes
Post by olyelr » Tue Oct 23, 2018 12:05 pm
Where are you located? Im sure there is someone with a Laramie near you that would trade you their chrome bumpers and grill for your setup... thats really the main difference (aside from door handles and mirrors, which could be switched also). If you are near northern MI then I might be game for it :mrgreen:
Re: New Shoes
Post by Bill2014 » Tue Oct 23, 2018 2:00 pm
Not to drive this thread further into the weeds - but I'd never give up my Laramie chrome!!! I'd have even paid an extra $500 - $1000 to have gotten the White Knuckle Sliders in chrome - even though it would get scraped off of the underside (where it cant be seen)!!
Re: New Shoes
Post by TankerZak » Tue Oct 23, 2018 3:36 pm
I'd give up my chrome in a heartbeat. The grill is already in my garage...
Bigdodge
Re: New Shoes
Post by Bigdodge » Tue Oct 23, 2018 10:03 pm
I'll trade my chrome for black anytime. Indiana
BoldAdventure
Re: New Shoes
Post by BoldAdventure » Wed Oct 24, 2018 10:05 am
TOO LATE :lol: I'm with you on that one. Everyone blacks everything out. I used to do that. But I like the chrome. Chrome is the new black. :P I think it makes the truck look classy.
Punishher7
Re: New Shoes
Post by Punishher7 » Wed Oct 24, 2018 11:35 pm
With the two tone paint and black fender flares, I’ll keep the black bumpers. All I’m saying is given the chance to get a 2018 w/ the Laramie trim I likely would have. Both packages look great though!
