o ring for p/s reservoir
w2dodge
Post by w2dodge » Mon Aug 20, 2018 6:36 pm
have a small leak between the pump and reservoir...cant find any part#s for this o-ring.. anybody ever change one?
Re: o ring for p/s reservoir
Post by Low_Sky » Mon Aug 20, 2018 7:36 pm
Barring finding an actual part number, can you get it to a Fastenal or Grainger and just measure it for a replacement?
Mule
Post by Mule » Mon Aug 20, 2018 8:14 pm
yup, or find a local industrial shop that can make an O-ring for you, if they don't have something off the shelf that'll work.
Bearing/motion supply shops can usually do some sealing work as well. I've got a shop nearby that specializes in seals/packing/O-rings.
Post by Colibri » Mon Aug 20, 2018 11:07 pm
I’ve changed it several times replacing pumps, you may have to buy a new reservoir to get the factory piece, or just disassemble and match it up to an o ring at an industrial place or Napa etc.
The factory connection between the reservoir and pump has the o ring AND a little plastic restrictor that can get brittle with age. So don’t lose that or break it just FYI
w2dodge
Post by w2dodge » Tue Aug 21, 2018 9:02 am
.. I found a used p/s setup online from an 05 p.w. from B&R auto wreckers in Oregon to keep as a spare...and do what you guys suggest with the o-ring...thanks
Post by Retired BLM Rig » Tue Aug 21, 2018 11:29 am
I have an extra small parts bag leftover from the last time I did a pump and reservoir, it comes with screws, o-rings and the little plastic restrictor, part# 68034315AB. I don’t know if its available by itself, but I think that’s what you need.
w2dodge
Post by w2dodge » Tue Aug 21, 2018 1:25 pm
if those parts work for a 05 p.w...il buy them..but what I found was all discontinued for my p.w..
Post by coder » Tue Aug 21, 2018 6:20 pm
Those look like they are for new PS I think I have some in my garage as well. Time to upgrade!
But if not, any hardware store that sells o'rings should have replacements just take your's in and find the matching size.
w2dodge
Post by w2dodge » Wed Aug 22, 2018 4:08 am
ok...il shop around for the o-ring then...shouldn't be hard to find one......
w2dodge
Post by w2dodge » Wed Aug 22, 2018 10:26 pm
well I took the p/s pump off...and it turns out it wasn't the o-ring but the pump its self..rear was leaking from the c-ring...any chance anyone have part#s ...?...or any 3 bolt pump will work...reservoir looks fine and also the scene..
Post by Retired BLM Rig » Fri Aug 24, 2018 1:55 am
O.E. part #68034330AB $460.00 +-.
Lots of choices on Napa's website, depending on your configuration: New/Reman, W/ or W/O reservoir, W/ or W/O pulley.
I would get something local, from a nationwide chain that is name brand and has a lifetime warranty. Then carry the receipt in your truck for when it dies again. :doh:
Flush your P/S & brake fluid every 30K and the components will be happy longer. (especially brake fluid, it's hygroscopic) :patriot:
w2dodge
Post by w2dodge » Fri Aug 24, 2018 5:50 am
just a thought... will a unit from 11-12 ram work?...thanks for p/n...
Post by Retired BLM Rig » Sat Aug 25, 2018 9:14 am
I don't know, maybe.
I would take the original pump to an auto parts store and make some comparisons side by side, focusing on mounting bosses, hose connections and pulley offset/shaft length.
Post by Colibri » Sat Aug 25, 2018 3:13 pm
A generic TC style pump will work. Much cheaper and can be had in higher output as well. Just needs a little work to mount a reservoir etc.
w2dodge
Post by w2dodge » Fri Sep 07, 2018 1:20 pm
new upgrade on pump..all new no refub... got a steal on ebay...putting the pulley on was a pain..made sure it was the same distance from the rear of the pump as the original
