2018 AEV Procal
2018 AEV Procal
Post by PWJouster » Fri Aug 03, 2018 1:34 pm
golden.
works as advertised. speedo is now in sync with GPS 2 ways. thank you AEV
attempting to clarify instructions with AEV but i do believe i ran into a mishap.
my 2018 has a secondary OBD2 harness that connects to factory obd and replaces the dash mounted obd with a secondary unit that had no available pin outlets. the stock OBD2 was floating under the dash, zip tied, and had the open ports to proceed.
dealer tech confirmed this is a security harness to prevent pretty much what we are trying to accomplish. i had concerns, but went ahead anyway.
All this would mean is that you do not need to remove the obd2 port from the dash mount if you have this harness.the obd2 port you need is floating under there.... so long as aev can confirm i didnt just flag myself up to the mothership. that security harness had a colorful multi wire lead up behind the driver front quarterpanel into oblivion. i thought someone had installed an Tracking device.
all is good.
17 Method NV-Toyo RT 35
Evo On-Demand Swaybar Disconnect
SPOD
Re: 2018 AEV Procal
Post by Reloaderguy » Fri Aug 03, 2018 2:08 pm
Can you take a picture?
Re: 2018 AEV Procal
Post by FordyceCreekTrail » Tue Aug 21, 2018 8:23 pm
Mine did not sync. Waiting for an engineer to figure it out. Brake light flashed 5x then 3x.
Re: 2018 AEV Procal
Post by Bill2014 » Wed Aug 22, 2018 7:03 am
Somebody is watching you now...
https://www.youtube.com/watch?v=wGPlCLf9AZ8
