Champion Plugs......
Re: Champion Plugs......
Post by Will » Sun Mar 13, 2016 7:40 pm
Changed mine today, 2 hours flat with regular tools. No swivels because they're in storage, all was done with 1/4", 3/8", ratchet with 3" and 6" extension with one 1/4-3/8 adapter.
Post by Will » Sun Mar 13, 2016 7:41 pm
Post by Colibri » Sun Mar 13, 2016 11:20 pm
Nice work :rockon:
Post by Will » Mon Mar 14, 2016 7:55 am
I also cleaned the inside of throttle body and I guess by flipping the butterfly open set off the throttle position sensor, or spray from carb cleaner got somewhere it should not have. When I started it, it hesitated an had a rough idle. I plugged in my tuner to read the codes and had P0123 & P0113. So I shut it down and disconnected/reconnected everything I had touched, including all of the coils. (At the time I didn't know what the codes were exactly.) I cranked it again and it was perfect, used the tuner to clear the codes. All is good, real smooth idle now and crisp throttle response.
P0113 - Intake Air Temperature Circuit High Input
P0123 - Throttle Position Sensor/Switch A Circuit High Input
For those on the fence about getting a tuner, ones like the Diablo InTune serve as a scanner and you can clear the codes too, so you're getting more than you think. Otherwise, I would have had to ride around with check engine light on until I could take it in to have it cleared, then they probably would've told me something needed to be replaced and suckered me for some money.
awdanthony
Post by awdanthony » Tue Mar 15, 2016 2:55 am
I also seafoam sprayed my throttle body, I feel like it helped response a little bit.
2017 Power Wagon L&L pack with some extras. In desperate need of 35s.
