2014+ Train Horn Recommendations?
Posted: Wed Jul 18, 2018 7:58 pm
by DirtyOffroad
Looking to do an OBA/Train Horn combo with a 2-3 gal tank. I'm not opposed to making my own setup but would likely buy a train horn kit with my own tank and oba bits. Looking for recommendations as I know this is a common install. I'd like to use my spare tire well for the tank if not the whole setup if anyone has done that.
Re: 2014+ Train Horn Recommendations?
Posted: Wed Jul 18, 2018 9:58 pm
by Reloaderguy
There was someone on one of the PW FB groups doing OBA and airhorn kits. He caught a ton of shit but the kits looked pretty good. I don't remember his name but it was some goofy site like airhornsRus or something.
Posted: Thu Jul 19, 2018 9:16 am
by verdesardog
I have a fire engine air horn on my CTD. I like it a lot, it gets 120 psi air from my 200psi OBA.
https://www.amazon.com/Wolo-846-Chief-S ... k+air+horn
Posted: Thu Jul 19, 2018 9:33 am
by PWJouster
hornblasters has the most cost effective and plug and play setups.
Posted: Thu Jul 19, 2018 7:18 pm
by SeppW
Kleinn Horns recently released bolt-on kits for Ram 2500.
Posted: Fri Jul 20, 2018 9:03 am
by PWJouster
SeppW wrote: ↑Thu Jul 19, 2018 7:18 pm
yea so ill be buying this asap.
https://kleinn.com/product/onboard-air- ... 734-horns/
look out for install within the next 2 months,
i once overed the install tech, seems well designed. i may setup a dual viair in the rambox though.
engineering of wiring may be off. it needs to have a horn momentary button and a toggle power switch. the way it is wired is relay to ignition power, but that means anytime the tank is low, the motor goes whirl.
i want control of when the motor can fill the tank.
Posted: Fri Jul 20, 2018 2:00 pm
by SeppW
Yes, Kleinn's circuit set up has system wired to run when the ignition is on. However, you could place a switch between the power source and the pressure switch to cut power on/off to pressure switch, thus the compressor will not run as long as the pressure sw is not energized.
Posted: Sat Jul 21, 2018 4:20 am
by Shaved Ice
I really like the Kleinn offering. It looks like the mounting location(s) conflict with White Knuckle Rock Sliders. I am sure it could be rectified, just something to consider.
Posted: Sat Jul 21, 2018 9:20 am
by DirtyOffroad
Looks like I'm going to build something to get what I want. Hornblasters offers the Shocker kit which is likely what I'll go with for horns. Going to put a 4 gallon pancake tank where the spare was, compressor will have to be custom fit somewhere but I can do that. Compressor will feed a multi-port tank with an OBA setup as well.
I'm thinking I'll run to OBA into one of the ramboxes with a hose on it so its ready to roll immediately and wont get gunk in the port.
Posted: Sat Jul 21, 2018 5:44 pm
by TwinStick
Posted: Sat Jul 21, 2018 6:38 pm
by Colibri
Murder Death Kill
Posted: Sat Jul 21, 2018 7:21 pm
by Reloaderguy
Enhance your calm.
Posted: Sun Jul 22, 2018 10:58 am
by DirtyOffroad
Colibri wrote: ↑Sat Jul 21, 2018 6:38 pm
Murder Death Kill
Love that movie
Posted: Sun Jul 22, 2018 11:09 am
by OffroadTreks
LOL, he doesn't know how to use the 3 sea shells
