Rear Suspension
ramv
Rear Suspension
Post by ramv » Fri Jul 06, 2018 10:35 pm
Currently Have Airlift Ultimate bags, Daystar cradles.
Planning on decent shocks (Thuren King 2.5"s). Would you do their rear coils and/or trackbar? Are the springs taller at all, if not, should I add a spacer?
I occasionally do tow and haul fairly heavy (SXS on deck, plus tongue weight of trailer likely is approaching 5000-5500 lb on rear axle. Nothing for the axle or tires, but definitely more than a half ton coil is designed for. Obviously the bags have capacity.)
Mainly I am empty though. (Just recovery gear/tire chains/gear bag)
Thoughts on rear suspension?
Re: Rear Suspension
Post by Reloaderguy » Fri Jul 06, 2018 10:40 pm
I would definitely do the rear trackbar, even if you intend to keep the entire truck stock. I'd probably skip the rear coils unless you're going to run Thuren tuned shocks. Since you already have airbags there is no point to adding a coil spacer.
Re: Rear Suspension
Post by TankerZak » Sun Jul 08, 2018 9:31 am
Do the rear trackbar. The stock one is what causes the rear to squat and wiggle around corners. If your going to run Kings then do his springs. They are matched well and a lot softer but you have airbags to compensate for towing. I'd add a Traxada one inch spacer on top of Thuren springs. Without it I was a hair nose high with the 1.5 springs up front.
2016 Granite Crystal Metallic Power Wagon Laramie, no graphics, debadged, Thuren front and rear coils, Traxada rear 1 inch spacer, Thuren rear swaybar links, Thuren rear trackbar, King 3.0 (Stage 4) front shocks, King 2.5 (Stage 3) rear shocks, Boogie front bump stops, Toyo RT 37x12.5R17 on Raceline Avenger 17x9 +20 wheels, DOR steering brace, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 synthetic winch line, Zroadz Grill with slim 20 inch light bar, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
Re: Rear Suspension
Post by DamageWagon » Sun Jul 08, 2018 12:58 pm
I spec’d a similar setup recently. The rear trackbar is going to be a really nice improvement and I recommend it for even a bone stock truck. Especially if you’re going to have weight up high you’ll want the rear trackbar and the handling improvement it gives.
You can do stock or Thuren rear coils BUT in order to run Thuren shocks you need his coils, due to their extended lengths being much longer so that your coils don’t fall out in full droop. I’ve done a few trucks with Thuren rear coils and a 1” spacer and that works well. He coils are softer but also taller when compressed so they ride much better but can still handle a fair load.
Having a SXS on top of the truck I’d go straight to King 2.5’s for the control they offer. You can still choose which stage valving you want but I’d probably stick in the 2-4 range and tell don your plans for the SXS.
Re: Rear Suspension
Post by nts007 » Tue Jul 10, 2018 11:46 pm
Track bar delete! Everyone's doing it
BoldAdventure
Re: Rear Suspension
Post by BoldAdventure » Wed Jul 11, 2018 12:05 am
To elaborate on this, for someone reason, there is a misconception that adding his coils will cause your ass end to drag worse than stock. I believed this too. I was wrong. It's really not that much worse than our stock coil. If comparing to a standard 2500, then it's noticeable. And I think somehow that got translated to the Power Wagons. But compared to how our trucks sag currently, it's a MINOR difference between the two. I posted measurements of this in my build thread awhile back I think with some weights in the truck.
Thuren's setup feels worlds better when you're running the whole deal. Especially when towing. That rear track bar is worth the money out of the gate. And is one of the first things I did.
Like DamageWagon said, you need to run his shocks with his coils for best results. But oh good golly, is it AMAZEBALLS
Hell, I towed with this setup, with NO AIR BAGS
I am running a 1-inch spacer because when combined with the WD hitch, it takes up the compression slack I had without using Airbags.
Re: Rear Suspension
Post by DamageWagon » Wed Jul 11, 2018 12:15 am
What the hell Mike? ‘A few half inches’?? ‘2/4ths inch...’??? What!? :ugeek:
BoldAdventure
Re: Rear Suspension
Post by BoldAdventure » Wed Jul 11, 2018 12:49 am
It's late and my brain is fried. Been looking at arrays and variables all day :thppt: ok so that made no fucking sense 2/4th but the point remains, the difference isn't OMG, it's more like, you need a tape measure to tell. :thppt:
BoldAdventure
Re: Rear Suspension
Post by BoldAdventure » Wed Jul 11, 2018 12:57 am
Retired BLM Rig wrote:
Wed Jul 11, 2018 12:50 am
:chug: :chug: :chug:
Don’t drink and post :lol:
there I fixed it :thppt:
Re: Rear Suspension
Post by Low_Sky » Wed Jul 11, 2018 9:55 am
:poke: Marcus, when am I getting my Thuren goodies so I can comment intelligently on these threads? Haha
2015 PW Laramie w/RamBox, 35"x12.50r17 Toyo C/Ts, custom rock sliders, PCP front/rear half-spiders, DOR steering brace, drinks Amsoil Kool-Aid, custom offroad pinstripes and extreme mud splash graphics
Re: Rear Suspension
Post by DamageWagon » Wed Jul 11, 2018 11:35 am
Those are mine now, you never came by to pick them up :rofl:
The skid plate will be ready in just over a week and I’ll get them all packed and sent out!
