Brakes squealing
Posted: Sun Jun 10, 2018 9:05 am
Anyone have issues with their brakes squealing during light to moderate braking? They dont squeal at all with no braking or hard braking. Under 20k miles and the pads and rotors look like brand new. Seems to only happen once they warm up a bit. Im at a loss, and it is getting extremely annoying.
Re: Brakes squealing
Posted: Sun Jun 10, 2018 10:38 am
by TankerZak
Brake dust most likely.
Posted: Sun Jun 10, 2018 10:47 am
by RPS1030
Break dust most likely.
Yup, all the time. Hose down through the wheels and it goes away for a while.
Posted: Sun Jun 10, 2018 12:58 pm
by Retired BLM Rig
Maybe Fluid Film overspray getting glazed on the pads and rotors. :wink:
It's like running your finger around the rim of a wine glass and making it sing, requires just the right amount of friction and speed to cause harmonic distortion, change one of the factors and it goes away.
You could try sanding the glazed surface off the pads and rotors. Takes a little time but doesn't cost anything. It might come back however.
Posted: Sun Jun 10, 2018 1:12 pm
Thanks fellas.
What would I use to sand them down with, just some fine grit sandpaper?
David, the fluid film comment made me lol, although it could certainly be the culprit!
Posted: Sun Jun 10, 2018 1:21 pm
by Retired BLM Rig
I would try 120 to start with.
Posted: Sun Jun 10, 2018 3:05 pm
by BoldAdventure
Long dirt roads and my just squeal. Dirt/Dust particles are the likely culprit if they aren't worn.
