Front and rear diff guards
Re: Front and rear diff guards
Post by coder » Sat Oct 20, 2018 6:55 pm
I've had both Purple Cranium and Carli front covers. The Purple Cranium leaked after some direct hits because it does not protect the bottom of the lip of the cover the Carli cover is the best. As far as it hitting more rocks that's not been my experience after 10 year of off road travels with it t's performed flawlessly.
Post by TankerZak » Sat Oct 20, 2018 7:08 pm
coder wrote:I've had both Purple Cranium and Carli front covers. The Purple Cranium leaked after some direct hits because it does not protect the bottom of the lip of the cover the Carli cover is the best. As far as it hitting more rocks that's not been my experience after 10 year of off road travels with it t's performed flawlessly.
Maybe an old design? Purple Cranium completely covers the lip...
Post by coder » Sat Oct 20, 2018 7:14 pm
Good to know, should work fine then.
BoldAdventure
Post by BoldAdventure » Sat Oct 20, 2018 11:14 pm
How did you peel the lip on the front diff? That took some stupid, in reverse.
