Rear Shock Question
vanished
Rear Shock Question
Post by vanished » Mon Apr 30, 2018 7:03 am
What Bilstein's do we have - 4600 or 5100? Does anyone have the part number for the rear?
Trying to figure out what to order, as it doesn't appear entirely clear for our trucks...
2015 MY, wasn't sure if they changed them at the 14+ update...
Or if anyone has any stock takeoffs laying around? :D
Found a puddle (ok, a few drops on my driveway) of oil under my right rear shock yesterday...
23k miles and two weeks out of warranty... :angry:
Thanks!
Re: Rear Shock Question
Post by olyelr » Mon Apr 30, 2018 8:22 am
With all the leaking issues I have heard with these shocks, I dont think I would be replacing them with the same thing.
Perfect time for the Thuren Overland upgrade https://www.thurenfabrication.com/produ ... ystem.html
If that is not in the budget or desires, maybe just snag his white body shocks or the King IFP shocks. He dosnt recommend them without his springs, but I cant imagine they would be all that bad with the stock springs.
And no warranty at 23k?! Ouch!!!!
Post by DamageWagon » Mon Apr 30, 2018 12:44 pm
Don’s Overland shocks are a really good option, very budget friendly. I’d do all 4 and enjoy the noticeable upgrade. Or fall into temptation and order Kings and put a fat smile on your face
Post by Low_Sky » Mon Apr 30, 2018 1:52 pm
When I killed my first set of OEM fronts, I let the dealership replace them with OEM units under warranty. No way in heck I'd pay out of my own pocket to put the same set of Bils back on the truck.
Post by Reloaderguy » Mon Apr 30, 2018 4:47 pm
Bisteins are garbage.
Post by coder » Mon Apr 30, 2018 7:23 pm
Thanks!
4600's/5100's are mechanically the same with a different finish and valving. PW shocks are a custom tuned version of the same shock. Bilstein's are leaky I've had multiple versions from 4600's to 7100's and they all leaked eventually.
In my option a 2" shock are to small for the PW no matter who makes them, if at all possible, save your pennies and get a set of 2.5 Kings.
Post by coder » Mon Apr 30, 2018 7:39 pm
delete...
vanished
Post by vanished » Tue May 01, 2018 11:24 am
So... I appreciate the feedback but I'm hearing factory shocks are junk and I need a good set of $500+ shocks...
I like it, not sure the wife will! ;)
Post by adeluca73 » Tue May 01, 2018 12:37 pm
Hey, come-on, you're vanished...if anyone can pull it off, you can. Tell the wife this is cheap insurance to insure against turning the PW into a Z71 style off-roader. :rockon:
Post by Low_Sky » Tue May 01, 2018 7:12 pm
Tell her it's for safety. The handling on these junk Bilsteins is unpredictable, and they may fail AT ANY TIME. Think of the children, Vanished.
Post by coder » Tue May 01, 2018 7:18 pm
I would not say Bilstein's are junk, I think that's' overstating the case. Toyota, GM, Jeep, Dodge, RAM all have their performance shocks made by Bilstein.
They are fairly high pressure and can blow seals. However I have removed OEM Bilstein's off a 1998 Grand Cherokee within the last year that had all the oil and pressure in them I'd say that's pretty good!
If you want to cut costs just order a replacement rear shock from Mopar. I've been using Rancho Mopar Parts they have the deepest discounts on OEM parts and 2015 have rear PW shocks for 34% off MSRP PN# 68233921AD or about $152.90 each + shipping/tax
https://www.ranchomoparparts.com/oem-pa ... OC1nYXM%3D
Post by olyelr » Tue May 01, 2018 7:32 pm
So is that still an OEM Bilstein, or a Rancho?
Post by coder » Tue May 01, 2018 7:42 pm
OEM Bilstein, Rancho is just the name of the dealership it's in San Diego California and everything has a spanish name.
vanished
Post by vanished » Wed May 02, 2018 7:18 am
Thanks Coder, that's what I was looking for...
Although at $160 a piece, the king 2.0 isn't 'too' much more... But by the time I do front and rear and convince myself the stock springs will be fine... Well - I guess a $320 fix is cheaper... :wink:
Oh and thanks Tony - I already have a complex going on with this truck as it's only seen minimal off road compared to my first two... Heck my GMC was in the woods more! :doh:
NickTF
Post by NickTF » Wed May 02, 2018 9:19 am
$160 a piece? Last time I checked half of $490 was $245??? Did I miss something?
vanished
Post by vanished » Wed May 02, 2018 9:59 am
$160 ea for OEM, $245 ea for Kings - but I would do just rears if OEM, but Kings would go all the way around..
NickTF
Post by NickTF » Wed May 02, 2018 10:03 am
I see.
Post by DamageWagon » Wed May 02, 2018 11:58 am
The King 2.0’s are Cadillac shocks, not for heavy off-roading but more for really comfy street and washboard roads. Or if you want to throw stock-ish shocks back on I’d just grab some Thuren Overlands, about $145 per pair and a very good all-round shock for these trucks, better than factory
vanished
Post by vanished » Wed May 02, 2018 12:30 pm
I like the 'stockish' approach... But will they sell them alone?
"Our rear shocks work with our rear coils ONLY, and our rear coil kit must use OUR shocks. More details on the coil spring page."
I admit I don't push my truck much but not sure if the suspension is truly that sensitive..
NickTF
Post by NickTF » Wed May 02, 2018 1:37 pm
For whatever it is worth I believe Thuren also indicates that his overland shocks are to only be used with his coils, same with the king 2.0s. Perhaps the valving is generic enough for the oem rear coils.
Post by Colibri » Wed May 02, 2018 1:54 pm
My understanding is it’s not so much about valving as length. Stock gas and diesel trucks have shorter coil free heights than power wagons or his own lift springs. You don’t want coil springs popping out on the trail as you articulate because your shocks are “too long”
NickTF
Post by NickTF » Wed May 02, 2018 2:27 pm
That makes alot of sense.
Post by olyelr » Wed May 02, 2018 2:37 pm
Yes. A simple test while installing them will let you know if there is indeed an issue with the PW coils being to short. If so, this could be remedies with some limiting straps.
But honestly, I am pretty sure the sway bars prevent even the OEM shocks from becoming completely extended. If not, it is very close.
NickTF
Post by NickTF » Wed May 02, 2018 2:48 pm
Since installing my front 1.5" coils and using the oem shocks up front I believe i'm hitting their max extended length during axle droop after hitting anything mildly aggressive (6" bumps/ruts, aggressive speed bumps square on, etc.). I got thunk/pop sound when it happens and all other suspects have been ruled out. I've been meaning to get the compressed and extended measurements of the front oem bilsteins for some time but haven't had the time seeing as how the truck spends so much time pulling a lawnmower trailer and our boat this time of year until well in to december (for boat anyway). I may solve it for the time being with a set of overlands until I can pony up for real shocks or may run 2.0 reservoir fox shocks which are about the same cost as the king 2.0s. Not in any hurry. Sorry for the partial derail.
Rodeoflyer
Post by Rodeoflyer » Wed May 02, 2018 7:47 pm
If Bilsteins are junk how do Ranchos rank? Less than junk?
