Air Box Hole Help
thedriver21
Air Box Hole Help
Post by thedriver21 » Sat Apr 14, 2018 9:52 pm
Need advice on covering the hole and shock mount in the air box after installing kings and the thuren shock mount. I went out to the mountains after installing said parts and was curious to see if there would be any water buildup since it was also raining that weekend. Sure enough, there was a tiny bit of water. How should I go about covering this up so its close to if not completely dust and water tight?
2013 PW Tradesman-Copperhead Pearl : 3in Springs, End links, 2.5in Stage 3 King Shocks, and Track Bar by Thuren, Carli Control Arms, 1in Synergy Shackles, Fastman 85mm Throttle Body, Jay Greene Tuning, Kicker Speakers All Around, Laptop GPS System
"I didn't become an EMT to get a front-row seat to other people's tragedies. I did it because I knew the world was bleeding and so was I, and somewhere inside I knew the only way to stop my own bleeding was to learn how to stop someone else's."
Re: Air Box Hole Help
Post by DamageWagon » Sat Apr 14, 2018 10:14 pm
Ha I just left mine open. More airflow. My Wix filter takes care of water ingress. Hit a creek crossing going 55 and pressure washed the engine compartment, pulled the filter on the other side and it was dripping with water but did not soak any in. Beat it on the bumper and put it back in! You could say I washed my filter.
