Morimoto fx’rs
Morimoto fx’rs
Spurred from another post. I have done some research on these Morimoto fsr projector upgrades.
Looks like a great improvement from stock
Has anyone done this mod?
How was the mod install?
And was the improvement worth it?
Thanks in advance.
Thanks in advance.
“ROCKY MOUNTAIN” TESTED
Re: Morimoto fx’rs
I put Morimoto projectors on my 05. Huge difference, like night and day.
The Retrofit Source is a good place to check them out
https://www.theretrofitsource.com/
Preview
AEM Brute Force intake
Gibson CAT back exhaust
Super Chips Flashpac Tuner
Wet Okole seat covers
Line-X bed coating
Trac Rac Sliding Lumber Rack
H2 rims
Line-X bed coating
H2 rims
Re: Morimoto fx’rs
When your high dollar HIDs shit the bed, and the retailer leaves your hanging, my $90 DDMs will still be chugging along.
Re: Morimoto fx’rs
I am assuming you all have stock projector housings....for those that do not....did you just look for projector housings on eBay or did you retrofit your housings with projectors? Stock headlights are no so good and I don't want to blind everyone on the road by putting HID/LED elements in stock housings. FYI I have a 2011 PW with dual not quad.
- continuecrushing
Re: Morimoto fx’rs
I bought headlights on ebay and did the whole retrofit on those. I also swapped from quad to projector too.
If you have factory projector headlights, you can get brackets to make everything essentially "plug and play" and I'd heavily consider the fx-r, d2s 4.0, or the G5-R projector (I chose the G5-R).
Re: Morimoto fx’rs
Amount of improvement depends on which year truck you have. Factory lights on my '05 were complete crap and I spent a bunch of money on various high watt halogen capsules and tweaks to get better light, but nothing was adequate. So I bit the bullet and ordered a set of retrofit projectors from RetroShop. I think he uses Morimoto components. They are not as good as I would like, but they are way better than stock or stock with the high watt capsules. Worth the money. Had a bad ballast (burned connector) and RS sent me a new one. Had the same problem on the other side a year later and those ballasts were no longer available from RS and I was beyond any stated or implied warranty, so I had to find a hole-in-the-wall car audio/alarm/window tint/lowrider shop that could get something that would work. They patched the light together with a little solder and duct tape and connectors they had on hand and got me going again, and it's been fine but I expect failure. I kept my old headlights just in case, looks like a good move. If I had a newer truck, I'd probably still play with different halogen capsules and fatter wires before I dropped big bucks on HID retros, but might still end up in the same place.
Re: Morimoto fx’rs
I would not put HID's in your factory housings.drdfblackm wrote: ↑Sun Feb 25, 2018 12:01 pmI am assuming you all have stock projector housings....for those that do not....did you just look for projector housings on eBay or did you retrofit your housings with projectors? Stock headlights are no so good and I don't want to blind everyone on the road by putting HID/LED elements in stock housings. FYI I have a 2011 PW with dual not quad.
So I have owned the Morimoto FX-R's. They are amazing, light output is superior to the factory projectors. From my experience with ebay projectors, they are worse than the factory OE projectors.
I had Morimoto FX-R projectors in my 1500 in lights I had built by the retroshop.us - and I used DDM Tuning HID's in them. Fantastically bright, excellent beam pattern with sharp cut off. Much better than the factory which is washed out. Even with my DDM HID's in them.
The only thing that has kept me from doing that all over again is the cost. It was substantial the first time, and when my LED's halos failed like 5 months later it really ticked me off. And I decided I was done with those kinds of mods.
After driving all night from Portland, OR to Boise, ID in shit weather, I honestly thought about my old headlights a few times.
Re: Morimoto fx’rs
I did my own work also. Fortunately on Gen 3 trucks it's super easy to get the lights off the truck to work on them. the one gripe I had was the poor quality of the resistors included with the wiring harness from The Retrofit Source. They were big, poorly made and failed (melted) early. I bought some Mil Spec resistors and have not had any issues since.
Preview
Line-X bed coating
H2 rims
Line-X bed coating
H2 rims
