PSC Hydro Assist $500 Off
Post by Reloaderguy » Wed Feb 14, 2018 2:04 pm
Re: PSC Hydro Assist $500 Off
Post by DamageWagon » Wed Feb 14, 2018 3:56 pm
Thanks for posting this, I was planning on doing their ram before Moab but if the whole box is included for that price I might grab the kit.
Post by DamageWagon » Thu Feb 15, 2018 1:06 pm
The sale is on the box itself, $500 off. $350 for big bearing boxes and $450 for those boxes tapped for hydro assist. They also have assist cylinders for $80 that have scratched paint (PSC zone -> garage sale).
PSC said their boxes are brand new (not reman’s), have larger bearings and sector shafts, larger piston, better seals. No core charge.
Boxes require Swepco fluid which is compatible with the stock pump, and the stock pump can power the box, no high flow pump required.
There are also 3rd gen options that use the stock pitman arm.
Post by olyelr » Thu Feb 15, 2018 3:05 pm
Good info here fellas!
Post by TwinStick » Thu Feb 15, 2018 5:07 pm
I called them. They are closed for day.
If I get the $450 gearbox for my 08', where would i get a new pitman arm & larger bushing for my steering gearbox brace ?
Post by Colibri » Thu Feb 15, 2018 5:25 pm
CJC Offroad carries both
Post by Reloaderguy » Thu Feb 15, 2018 6:33 pm
This was just supposed to be an FYI for anyone interested in a deal on hydro assist. Looks like my garage floor just got some hydro assist. :chug:
Post by TwinStick » Thu Feb 15, 2018 7:07 pm
:lol:
Post by Reloaderguy » Thu Feb 15, 2018 8:29 pm
15% off and free shipping on Toyo tires.
https://tirecrawler.com/shop/promos/det ... mo_id/322/
Post by olyelr » Thu Feb 15, 2018 8:58 pm
Damn too bad that deal wasnt on bee eff goodrenches they are the best.
Post by Reloaderguy » Fri Feb 16, 2018 9:43 am
You need hydro for 42's, just sayin'.
Post by Reloaderguy » Sat Feb 17, 2018 11:39 am
Damage Wagon is working on tie-rod brackets for 14+ trucks. For anyone on the fence, this is a bolt on application for 4.5 Gens. If you went with the AEV installation kit and the PSC parts, this would normally be a $1500+ mod for just the parts. On sale and using DW's parts you're looking at a little more than half the price.
Post by RustyPW » Sat Feb 17, 2018 4:33 pm
I have the box and hydro-assist. Never installed the assist yet.
Russ NRA Benefactor Member
