Tailgate emblem removal
hemihead2
Post by hemihead2 » Wed Jan 31, 2018 8:44 am
I recently bought a tailgate and need to get the existing emblems off. Is there an acceptable way to do it so as not to ruin the underlying paint? Heat? Cold? Scraping? Solvent? Anyone have an experience doing this? Thanks all!
waldo
Re: Tailgate emblem removal
Post by waldo » Wed Jan 31, 2018 9:11 am
Decals or the metal ones like on the 3G trucks? The chrome plated ones with adhesive backing can be removed by working dental floss back and forth under them.
2007 and 2016 Power Wagons
hemihead2
Post by hemihead2 » Wed Jan 31, 2018 9:42 am
Yeah- 3rd gen...floss is an awesome idea!
Post by olyelr » Wed Jan 31, 2018 9:52 am
Heat and fishing line.
waldo
Post by waldo » Wed Jan 31, 2018 9:55 am
Yeah, fishing line works too. :P
Pit Slave
Post by Pit Slave » Wed Jan 31, 2018 11:02 am
After it's off, there's a rubber wheel drill attachment that makes it a breeze to clean the residual adhesive off. Only I can't remember what it's called at the moment... :doh:
DirtyOffroad
Post by DirtyOffroad » Wed Jan 31, 2018 12:30 pm
Pretty sure its universally known as "the rubber wheel thing that goes on the drill"
Here's a link to an "eraser wheel" or whatever :)
https://www.amazon.com/dp/B018WG2XYE/re ... 2428562227
2018 Ram 2500 Powerwagon
Post by Colibri » Wed Jan 31, 2018 2:59 pm
Another vote for floss or fishing line here!
Post by TankerZak » Fri Feb 09, 2018 5:34 pm
I just debadged. Fishing leader, 3m eraser wheel, 3m adhesive remover, plastic razorblades, and some type of cleaning/wax stuff for when your done or need to clean it to continue.
2016 Granite Crystal Metallic Power Wagon Laramie, no graphics, Thuren front coils 1.5, Dethloff skid plate, Toyo RT 35x12.5R17, DOR Steering Brace, Front and rear Purple Cranium Spider Diff Protectors, Airlift Ultimate Airbags with Daystar cradles, Boogie bump stops, AMP Bedstep, Whiteknuckle rock sliders, Bakflip Revolver X2 tonneau, Factor 55 Ultrahook, Magnaflow 19200 upgraded resonator.
Ducky's Dad
Post by Ducky's Dad » Sat Feb 10, 2018 8:26 pm
Or, you can soak the adhesive with WD-40 and slip an old credit card behind the emblems. Then, wipe off the excess adhesive with WD-40. I debadged an entire Grand Cherokee that way, with no damage to the paint.
