Another Airlift 5000 Ultimate/Daystar Cradles Install
ramv
Post by ramv » Sun Dec 31, 2017 7:46 pm
After reviewing this thread, I decided to go forward
http://forum.powerwagonregistry.org/vie ... f=2&t=4732
Went with the Ultimate for the internal bumpstop. Will install Wireless air compressor tomorrow.
Install was pretty simple. Need 5.5 mm and 6 mm allen keys, 30 ft lb torque wrench, 9/16" combo wrench (preferably ratchetting). 3/8" ratchet with 16 mm, 9/16" and 5/8" sockets, wheel nut socket, 1/2" drive 21 mm socket and 21 mm wrench. 1/2" open end to install air fittings. 1/" pilot bit, 5/16" bit, 3/8" tap, tap handle. Wd-40. 1.5 ton or better floor jack, two HD jackstands. Sharpie
First step was to build out the airbags in the house where it was warm
Next was to take off wheel, bump stop, spacer and lower shock bolt. Drop the axle all the way down. finger tight install of airbag, line up the days star cradle. Mark with sharpie.
Strip off airbag and mount. Use 1/8" bit to drill pilot hole. Proceed to drill 5/16", thread hole. Install daystar cradle. Reinstall upper mount (torqueing allen head bolts for brackets to 30 ft lb).
Re-install shock bolt, put tire back on, repeat on other side.
Remaining parts from not using lower mounts. Weight increase seems minimal as bumpstop spacers were quite heavy. Overall height seems perfect with no spacers.
ramv
Re: Another Airlift 5000 Ultimate/Daystar Cradles Install
Post by ramv » Mon Jan 01, 2018 6:34 pm
Installed the Wireless one compressor and remote solenoid today. I mounted it to the front of the bed support frame under the drivers side. There was a ground stud on the frame for the fuel filler so I connected the compressor and solenoid to that.
The solenoid is well above the frame rails and the compressor is about halfway up. I aimed it down as the larger vents appeared to be on the top.
Used the supplied fuse adapter to connect to the Fuse 90/91 (rear power point).
Teed in a line to the rear bumper with an air valve that can be used as back up if the compressor isn't working.
I did have to sync the remote to the control solenoid, not too hard just take the cap off the yellow wire and ground it while plugging the solenoid in.
Remote is super cool, one touch to go to your two settings (can add a third as well), I have 5 psi and 50 psi programmed in. Air compressor is adequate for this application (takes a couple of minutes to go from 5 to 50 psi.)
At 80 psi, the truck is noticeably tail high compared to stock, this is with no oem PW bumpstop spacers, just daystar cradles mounted directly to the axle.
Post by olyelr » Tue Jan 02, 2018 6:47 am
:rockon:
I want that little bugger BAD!
aheiser
Post by aheiser » Tue Jan 02, 2018 12:23 pm
Nice! Is there a reason you guys are going with the Airlifts instead of the Firestone kits? Not sure if I missed it or if it's the only option on 14+ trucks. I have a 2012 that I'm really thinking of putting a set on
Post by olyelr » Tue Jan 02, 2018 2:14 pm
Airlift has one with an internal bump-stop. So you can run the bags with 0 PSI. Not sure if Firestone has that option... never looked at them
israelstanage
Post by israelstanage » Tue Jan 02, 2018 8:02 pm
Minimum PSI on the firstones is 5. But that is also the minimum for the airlift compressor, so anybody planning to run 0 psi with on board air needs to make sure it's doable with whatever compressor setup they choose. I went with Firestone bags because the compressor setup I chose has a 5 psi minimum and the guys I bought from thought the Firestone bags were better.
Also, I think someone mentioned the airlift bags are approved for use with the daystar cradles. I don't know if Firestone bags are, but I did it anyway. I'm a real rebel like that.
Post by olyelr » Tue Jan 02, 2018 8:36 pm
Lmao!
Post by TankerZak » Tue Jan 02, 2018 9:52 pm
Yeah, Firestone came out with a statement saying Daystar craddles were a no go. So with Daystar craddle option and internal jounce bumper to run 0 PSI the Airlift Ultimates were a no brainer for me. They also aren't so bulgy so i think they work in craddles better. Remember when you compress an airbag you raise the PSI. So even at say 5 PSI when you flex and compress it might take away a little compression and flex of the rear axle. I feel much better running at 0 without a compressor and ignoring them until i need them. That's my thought process anyway. For better or worse.
ramv
Post by ramv » Wed Jan 03, 2018 2:06 pm
Exactly on the Airlift. Even with the air compressor, if you have an airline failure you won't damage the airbags. Seem to work well with the Daystars. I wouldn't have had a problem with the Firestones though, just thought the bumpstops were a good idea.
ramv
Post by ramv » Sun Jan 07, 2018 9:43 pm
Tried 50 psi out with the trailer. Worked good although was a bit stiff, backed it down to 40 psi for the ride home...
With the second gen on the car hauler, guessing 60 psi+
Post by olyelr » Sun Jan 07, 2018 9:59 pm
Nice!
All summer I wanna say I used around 30 psi with our travel trailer (7000lb’s empty). That is with a weight distribution hitch, which was set up for no bags or leveling kit.
The few times I hauled my buddy’s Jeep with a car hauler I was around 30 psi also.
Of course, both of those situations were with the factory power wagon bumpstop spacer installed... I have not hauled anything since I took them out.
Post by TankerZak » Sun Jan 07, 2018 11:00 pm
Nice!
Looking forward to spring. Need to re-setup my trailer after leveling and airbags. I expect it to be significantly better.
ramv
Post by ramv » Mon Jan 08, 2018 12:37 pm
Nice!
Cool, I'll try 30 psi next time!
Post by olyelr » Mon Jan 08, 2018 2:13 pm
Do you use a weight distribution/sway control hitch with your travel trailer? If so, and the fact you still have the factory rake, I would doubt you really even need much air in the bags (if any at all) for that trailer (looks relatively small/light).
ramv
Post by ramv » Mon Jan 08, 2018 11:52 pm
Not hooked up in the picture... Now WD hitch, I use one when I tow my carhauler but not for the travel trailer. It's ~ 5k lb, but tongue heavy, around 750 lb or better. (Many people with the same trailer weigh it loaded over 800 lb tongue.)
The bags made a couple of inches of difference when hooked up. Enough to where I ordered a deeper drop Class V hitch.
This will it allow to be level if I do a leveling kit.
