Brake pedal shakes violently on washboard road ?
JD 500
Post by JD 500 » Mon Dec 18, 2017 6:26 pm
Was on a fairly nasty washboard road Saturday while pheasant hunting. Brake pedal shook so hard and loud I was a bit concerned.
That normal ?
This is my first solid axle fwiw.
Thanks
JD 500
Re: Brake pedal shakes violently on washboard road ?
Post by olyelr » Mon Dec 18, 2017 9:31 pm
Never had it happen to mine, but then again I have not traveled many washboard roads with it.
Did you grab ahold of it and wiggle it to see if it is loose?
ramv
Post by ramv » Mon Dec 18, 2017 10:09 pm
My second gen and this truck do it. I assume it's a Dodge thing
JD 500
Post by JD 500 » Tue Dec 19, 2017 12:44 am
I did. Got under there with a flashlight. Isn't like there is a bolt loose, both pedals hang from a cast bracket
and there is so much stuff attached to the pedals I guess I'm not surprised now that I see it. There is a small amount of play side to side on the brake pedal.
I've been on washboards coming downhill in the mtns, but I guess this was the first on a flat dirt road. Coming downhill I would probably have my foot on the brake which would eliminate the shake.
Post by Bill2014 » Tue Dec 19, 2017 7:52 am
Do you have the adjustable pedal option?
Post by OffroadTreks » Tue Dec 19, 2017 10:39 am
Don't have that problem, and I'm on a lot of washboard roads.
Ducky's Dad
Post by Ducky's Dad » Tue Dec 19, 2017 11:06 am
If it shook when you applied the brakes, it's probably the ABS kicking in. Washboard confuses the crap out of the ABS computer.
JD 500
Post by JD 500 » Tue Dec 19, 2017 3:57 pm
Yes sir.
JD 500
Post by JD 500 » Tue Dec 19, 2017 3:59 pm
Nope. Was on gas pedal on flat road, brake pedal was shaking side to side.
Post by nts007 » Wed Dec 20, 2017 12:18 am
It was just excited for its turn.
aheiser
Post by aheiser » Wed Dec 20, 2017 10:10 am
My '12 has always done that. Like you said, washboard roads especially, sometimes you hit just the right frequency or vibration and you can feel the whole pedal set rattle a bit.
flattire
Post by flattire » Wed Dec 20, 2017 11:46 am
Did you grab ahold of it and wiggle it?
:excited: :rofl:
Post by Bill2014 » Wed Dec 20, 2017 1:47 pm
Yes sir.
I believe that is an issue that only affects the vehicles with the adjustable pedals option. The whole pedal set can shake around. :popcorn:
JD 500
Post by JD 500 » Fri Dec 22, 2017 6:10 pm
Yes sir.
Still worth having the adjustable pedals, Thanks
JD 500
Post by JD 500 » Fri Dec 22, 2017 6:11 pm
:excited: :rofl:
How did I miss that ? :cheers:
flattire
Post by flattire » Fri Dec 22, 2017 6:44 pm
It was solid advice.....but just made me laugh when I read it.
