Thanks for the pictures. Appreciate it!Low_Sky wrote: ↑Sun Jan 21, 2018 6:29 pm35x12.5R17 Toyo C/Ts, 40 psi front, 35 psi rear. I lose 1/4 turn of the wheel, where the fronts rub on the swaybar ends (first) and the radius arm knuckles. I live up a valley in south central Alaska and it can be a while before the sand trucks get up here when it's icy, so these things are well worth having.
I'm thinking about ordering a set of diamond chains for a smoother ride when I need to do more miles
Tire chains
Re: Tire chains
