Check this PW out. Found it on FB.
Post by TankerZak » Fri Dec 01, 2017 10:46 pm
2016 Granite Crystal Metallic Power Wagon Laramie, no graphics, debadged, Thuren front and rear coils, Traxada rear 1 inch spacer, Thuren rear swaybar links, Thuren rear trackbar, King 3.0 (Stage 4) front shocks, King 2.5 (Stage 3) rear shocks, Boogie front bump stops, Toyo RT 37x12.5R17 on Raceline Avenger 17x9 +20 wheels, DOR steering brace, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 synthetic winch line, Zroadz Grill with slim 20 inch light bar, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
Easttnrhino
Re: Check this PW out. Found it on FB.
Post by Easttnrhino » Sat Dec 02, 2017 6:38 am
Nice looking wonder what part of the world it's in.
2017 wagon in beautiful east tn
flattire
Post by flattire » Sat Dec 02, 2017 10:39 am
Looks like there is a "no smoking" sign and "no parking" red stripe. USA?
Sure is a big station.
PW at a gas pump? Good place for it.
Post by TankerZak » Sat Dec 02, 2017 11:24 am
It's in Texas. That bumper is something else!!
RPS1030
Post by RPS1030 » Sat Dec 02, 2017 1:14 pm
Bucees definitely equals TX
2016 Power Wagon Tradesman-White-37" Toyo RTs/Inyati Bedliner/Baja Designs Squadron Sports/CVT RTT/Metalline Fab Bed Rack
FToy #43
BoldAdventure
Post by BoldAdventure » Sat Dec 02, 2017 3:15 pm
That's Chris Coopers truck.
https://www.instagram.com/nomad1977/
Post by TankerZak » Sat Dec 02, 2017 5:45 pm
I just thought it had some interesting mods, especially that bumper. Thought I'd share!
Post by RustyPW » Sat Dec 02, 2017 6:04 pm
You see the camper top?
Russ NRA Benefactor Member
Post by TankerZak » Sat Dec 02, 2017 6:59 pm
Oh wow... that's a camper... that's super cool. Shell lifts into the lid....
TexasTJ
Post by TexasTJ » Sun Dec 03, 2017 11:46 pm
Yep, he's in Austin, TX and the bumper is the Intimidator prototype from Road Armor. He's talking about bedlining the whole rig next.
Flips forwards for hood access.
Post by Low_Sky » Mon Dec 04, 2017 10:14 am
Haha, yeah, I hate seeing over the hood too.
2015 PW Laramie w/RamBox, 35"x12.50r17 Toyo C/Ts, custom rock sliders, PCP front/rear half-spiders, DOR steering brace, drinks Amsoil Kool-Aid, custom offroad pinstripes and extreme mud splash graphics
13BlkPowerWagon
Post by 13BlkPowerWagon » Mon Dec 11, 2017 1:45 pm
If Bane had to have a truck... that's the bumper he'd put on it...
MSCH2112
Post by MSCH2112 » Tue Dec 12, 2017 12:28 am
that front bumper is intimidating enough. has to weight a ton..... and doesn't rhino lining the whole truck add several hundred pounds?
mike
2017 Ram 2500 Longhorn Cummins, 20" wheels for some lucky buyer someday
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Zybane
Post by Zybane » Sun Dec 17, 2017 8:00 pm
Pointless weight/overkill would be one way to describe that bumper.
Post by TwinStick » Wed Dec 20, 2017 11:20 pm
Yup, ..............until you hit a large animal. Then it pays for itself.
Hitting deer is a real & regular occurrence around me.
Rodeoflyer
Post by Rodeoflyer » Thu Dec 21, 2017 6:47 pm
That's the buc-ee's outside my neighborhood. He's probably headed south on I35 to go hunting on a ranch. Very cool. Haven't seen that truck around.
Post by RustyPW » Fri Dec 22, 2017 12:14 am
I've hit 6 so far with my PW. :shock:
Post by TankerZak » Fri Dec 22, 2017 9:41 am
6!?!?!? You know you can buy those 2 dollar air whisltes that mount on your bumper to scare the deer away! Sheesh that's a lot...
Post by RustyPW » Fri Dec 22, 2017 7:52 pm
Those air whistles don't work.
Guy I used to work with gets one every fall with his truck. Sometimes 2. Last I know. He was at 17, and that was 4 years ago.
Where I live at. We don't have enough people (3,600) for recycling of garbage in the township. It's mostly farm land, woods, and gas drilling. Perfect for deer.
I hit a cow one night that was on the road,. Missed the first two cows and hit the 3rd, With a motorcycle. :shock: My count so far is 9 deer, 3 dogs, 1 cow, 3 wild turkeys, and dozens of snakes.
Had a friend hit a horse one night with a motorcycle. He killed the horse and himself. :(
Post by TankerZak » Fri Dec 22, 2017 8:33 pm
Geezuz....
Post by Reloaderguy » Sat Dec 23, 2017 2:44 pm
What do you think is the lowest common denominator?
Post by TwinStick » Sat Dec 23, 2017 4:49 pm
I have been lucky so far with the PW. Had MANY a close calls though. IME, the BEST deterrent is loud knobby tires, period. I had those deer whistles on one of my old trucks. Hit 3 deer in 1.5 yrs AFTER I put them on. Loud tires can be heard a long ways away. Makes deer just stand still & watch you go by. I watched 1 of my co-workers get hit by a herd of deer, right in front of me. He had an S-10 Blazer. They were running at full speed. 1 hit his pass door so hard, it would not close afterwards & also took the mirror off-broke it's own neck & died. Another went right through the back side window & inside the truck---which helped total it---it was not dead & destroyed the interior. The 3rd was Rudolf I think because it jumped so high it literally went over the roof rack bars !!! Crazy.
Post by TankerZak » Sat Dec 23, 2017 5:37 pm
I take it all back. Forget the whistles. You need a GoPro, a Youtube channel, and a good narrator like James Earl Jones, Morgan Freeman, or that australlian guy with the outdoor channel.... (yes i know at least one maybe two if them are dead... that's just a minor barrier).
Post by RustyPW » Sat Dec 23, 2017 7:31 pm
Location, Location, Location. Lots of small towns, lots of woods, lots of farm land, lots of atv's. When someone goes into the woods, the farmer goes into his fields. They move the deer around. Right onto the road. I70, RT51, I79, Toll 43, are well known kill zones. You can't drive a mile without seeing a dozen dead deer on those highways. :shock:
