New Shoes
ramv
New Shoes
Post by ramv » Sat Nov 04, 2017 8:28 pm
Will get pics tomorrow. Went 315/70R17 BFG AT KO2s on stock rims on my 2016 Laramie PW. Main reason for 315s over 35"s (nearly the same size according to BFG) is you can get emissions testing done in Colorado with 315s. 35"s kick you out. (need to install smaller rollers for the dyno testing.) Also, I figure as stock OEM replacement for H2 and Raptors, might be easier to find a roadside replacement. $280 each from Pep boys.
No noticeable difference in driving (other than my TPMS light is off.) I used the Procal to set the tire size to 34" to start. Will dial in.
The tires look very stockish for the size of the truck. When I put 315s on my 2nd Gen they looked huge in comparison.
Plenty of snow today in the mountains when I was out hiking and winter storm warnings for tomorrow, so I am happy to have the peak winter rating for my daily driver.
2016 Power Wagon; White Knuckle sliders, 315 BFGs, BD 2Lo Kit, AEV ProCal, Airbags/Daystars
Re: New Shoes
Post by TwinStick » Sat Nov 04, 2017 11:21 pm
:wtf: NY State will probably jump on that band wagon as well soon! :angry:
Looking forward to the pics. :popcorn:
Re: New Shoes
Post by olyelr » Sun Nov 05, 2017 9:04 am
:nopics:
Another thing about the 315s vs the 35s is one of them (cant remember which one) is rated to fit on a wheels as skinny as 8” and the other is 8.5”. So, depending on where you go to get the tires mounted, that could be a deal breaker too.
ramv
Re: New Shoes
Post by ramv » Sun Nov 05, 2017 11:48 am
good point on the wheels too, these are rated for 8" wide as opposed to 35"s.
Re: New Shoes
Post by coder » Mon Nov 06, 2017 5:19 pm
Looks good!
Re: New Shoes
Post by adeluca73 » Wed Nov 08, 2017 2:05 pm
NICE!
2014 Ram PW SLT: Two tone Flame Red & Black
Completed Mods: Ram door sill guards, Front air deflector, WeatherTech slimline window deflectors, DiamondBack HD cover coated w/ Line-X, Mufflex MagnaFlow muffler & Resonator delete, Opti-Coat Pro 2.0, DeeZee tailgate strut, DeeZee ¼" fitted bed mat, Factor-55: FlatLink winch hook/Shorty Strap 3.0/Hitchlink 2.5, Warn Wireless Winch Remote, Locker by-pass, AEM dry filter, Truxedo LED bed lights wired into RamBox Connector, WhiteKnuckle sliders w/ full-length diamond plate coated in Line-X, Purple Cranium rear diff guard, AEV front/rear diff cover, AEV RAI w/ pre-filter, AEV ProCal (Bootleg'd), DOR Steering Box Brace, Phillips Hi intensity LEDs in cargo lamps & back-ups, triple anti-hop shocks, Truxx PW specific front 1.5" level, AAM 4.88's, custom black-out work, Line-X front/rear bumpers & wheel flares, 37" Nitto Ridge Grapplers, Plasti-dip PW wheels Black w/ Gunmetal metalizer, FilterMag kit, AMP Research BedStep
Next Mods: Thuren: {Coils, Track Bar, Boggie Bumps, King 2.5's shocks} , on-board air, HID low CANBUS replacement, LED HI, BD LED fogs
ramv
Re: New Shoes
Post by ramv » Mon Nov 13, 2017 8:57 pm
33.25" Seems to be about perfect setting on the Procal. 33.5" was off by ~ 1mph
