3rd Gen Front Driveshaft Removal?
Post by coder » Sat Oct 28, 2017 6:21 pm
Has anyone done this? I removed the bolts at the front axle first but can't seem to find a way to access the bolts were the driveshaft attaches to the transfer case the transmission brace is in the way? I have the shop manual it simply says remove the bolts.
Thoughts, opinions, tips, tricks, or random ideas welcome.
Re: 3rd Gen Front Driveshaft Removal?
Post by RustyPW » Sat Oct 28, 2017 6:54 pm
Peter did. He replaced his stock shaft with a NAPA shaft I believe. Can't remember the thread.
Vee
Post by Vee » Sat Oct 28, 2017 8:04 pm
I did mine, just don't remember how. I think I just used a long extension for that end. It was harder at the axle end because of the torx bolts. You need a long torx on a socket drive to get enough leverage.
Post by nts007 » Sat Oct 28, 2017 9:59 pm
Either a really long extension with wobble or get in there with stubby ratchatting gear wrench. Do a bolt. Rotate shaft. So the next
Post by TwinStick » Sun Oct 29, 2017 2:39 pm
What ??? I just remove the skid plate & bamm, it's right there. 5/8" bolts & I use a ratcheting wrench. I do loosen them a little before I remove the front axle side bolts. I also switched from the stupid torx head bolts (axle side) to hex head bolts. Much easier. I usually have the d-side front tire off the ground, so I can rotate the d-shaft by turning the tire with my foot, while under the truck. No stubby wrench needed, just a regular box end wrench or ratchet wrench.
Post by nts007 » Sun Oct 29, 2017 6:57 pm
When you're doing this in 25 below zero you get it off fast as you can. No time for skid plate removal. Especially when it's got 2-3" of ice on it lol. I wish I had a picture that day.
TrueCowboy426
Post by TrueCowboy426 » Sun Oct 29, 2017 8:21 pm
I hear you on this! Been there done that. I use a flex socket with a long extension on my little 3/8 impact and you can get them off pretty quick when you are freezing, with the wind blowing snow in your face, lol.
Post by coder » Mon Oct 30, 2017 12:44 pm
Hello TwinStick and TrueCowboy426,
I noticed you guys both have G56's I have an automatic. I'm wondering if there is more clearance when accessing the driveshaft at the transfer case with a manual because I could not get enough room to turn a full sized wrench at all so I will mostly likely be purchasing a stubby 16mm.
Thanks for everyones input feel free to keep the recommendations coming!
Post by TwinStick » Tue Oct 31, 2017 7:07 pm
:idea: You may be onto something there coder. I know they do have different d-shaft lengths for the auto & G-56. My skid plate is currently off mine (Just changed the t-case fluid & still gotta remove & lube the double cardan joint on the front d-shaft), so hold on, I'll go check.
Ok, the G-56 manual trans housing is shorter by a few inches. The t-case side, front d-shaft bolts are about 1/2" forward of the cross brace. Just enough to get a box end wrench or a ratchet wrench in there. First time ever that luck went in my favor !!! LOL :lol:
So, it would seem you could get them off easy enough with a battery or air impact, an extension & a wobble adaptor, after removing the skidplate.
