Page 2 of 2
Re: Steering Braces
Posted: Sat Nov 04, 2017 11:11 pm
by DocPaulo
Put this in last year and havent had any issues... didnt have issues before but i wanted to be proactive... hardest part of install was dropping the swaybars... those things are heavy and had to use a jack to line it back up
Re: Steering Braces
Posted: Thu Nov 09, 2017 9:27 pm
by whitey
I was snapping sector shafts off my 06 power wagon's steering box after putting on 37"s. The 06' originally had the smaller steering box but I think rock crawling with our heavy trucks and lockers engaged is a risk to the larger box too. I have hydro assist, a steering brace attached to the drivers side only and of course the larger steering box. I also have the Dynatrac ball joints and free spin kit. The steering brace is a good first step with 37"s. I feel like the 2nd weak point is the tie rod end links. Dodge and a significant part of the aftermarket tend to upgrade the tie rod but not end links. I've beat up some tie rods but never bent one (knock on wood). End links however have also snapped in two for me.
Re: Steering Braces
Posted: Sun Nov 12, 2017 7:00 pm
by TankerZak
Steering brace installed today. Everything lined right up after a bit o struggle with the smart bar. Even tightened up the steering some on a 2016. Very worth it!
FYI the main nut we had to remove was LOOSE. It's supposed to be torqued to like 185ft-lb and it was finger tight...
Re: Steering Braces
Posted: Mon Nov 13, 2017 12:48 pm
by Rodeoflyer
Everyone I've ever heard of who's installed a steering brace said the pitman arm nut is loose. I torqued mine down good along with the draglink nuts when I first brought the truck home.
Re: Steering Braces
Posted: Mon Nov 13, 2017 2:38 pm
by DamageWagon
Rodeoflyer wrote: ↑Mon Nov 13, 2017 12:48 pm
Regardless of t being a new truck, this is a very good idea. It seems like everyone who checks has been verifying the drag link adjuster and pitman Arm nuts are poorly torqued form the factory.
Re: Steering Braces
Posted: Mon Nov 13, 2017 10:33 pm
by ramv
On my 2nd gen, I retorque the pitman arm nut every time I drive it. Rock crawling loosens up a lot of parts quickly
Re: Steering Braces
Posted: Mon Nov 13, 2017 11:45 pm
by TankerZak
I drove my truck about 60 miles today. This steering brace is night and day improvement. Steering is so much firmer and smoother. Its far and away much more than i expected. If i woulda know itd be this good i woulda done it a year ago.
