Steering Braces
DocPaulo
Re: Steering Braces
Post by DocPaulo » Sat Nov 04, 2017 11:11 pm
Put this in last year and havent had any issues... didnt have issues before but i wanted to be proactive... hardest part of install was dropping the swaybars... those things are heavy and had to use a jack to line it back up
Auxbeam 42 curved lightbar
RANCHO 9000XL suspension
EMF ball joints
whitey
Re: Steering Braces
Post by whitey » Thu Nov 09, 2017 9:27 pm
I was snapping sector shafts off my 06 power wagon's steering box after putting on 37"s. The 06' originally had the smaller steering box but I think rock crawling with our heavy trucks and lockers engaged is a risk to the larger box too. I have hydro assist, a steering brace attached to the drivers side only and of course the larger steering box. I also have the Dynatrac ball joints and free spin kit. The steering brace is a good first step with 37"s. I feel like the 2nd weak point is the tie rod end links. Dodge and a significant part of the aftermarket tend to upgrade the tie rod but not end links. I've beat up some tie rods but never bent one (knock on wood). End links however have also snapped in two for me.
Re: Steering Braces
Post by TankerZak » Sun Nov 12, 2017 7:00 pm
Steering brace installed today. Everything lined right up after a bit o struggle with the smart bar. Even tightened up the steering some on a 2016. Very worth it!
FYI the main nut we had to remove was LOOSE. It's supposed to be torqued to like 185ft-lb and it was finger tight...
2016 Granite Crystal Metallic Power Wagon Laramie, no graphics, debadged, Thuren front and rear coils, Traxada rear 1 inch spacer, Thuren rear swaybar links, Thuren rear trackbar, King 3.0 (Stage 4) front shocks, King 2.5 (Stage 3) rear shocks, Boogie front bump stops, Toyo RT 37x12.5R17 on Raceline Avenger 17x9 +20 wheels, DOR steering brace, Thuren King Steering Damper, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 synthetic winch line, Zroadz Grill with slim 20 inch light bar, DDM Tuning LEDs/HIDs, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
Rodeoflyer
Re: Steering Braces
Post by Rodeoflyer » Mon Nov 13, 2017 12:48 pm
Everyone I've ever heard of who's installed a steering brace said the pitman arm nut is loose. I torqued mine down good along with the draglink nuts when I first brought the truck home.
Re: Steering Braces
Post by DamageWagon » Mon Nov 13, 2017 2:38 pm
Regardless of t being a new truck, this is a very good idea. It seems like everyone who checks has been verifying the drag link adjuster and pitman Arm nuts are poorly torqued form the factory.
Re: Steering Braces
Post by ramv » Mon Nov 13, 2017 10:33 pm
On my 2nd gen, I retorque the pitman arm nut every time I drive it. Rock crawling loosens up a lot of parts quickly
2016 Power Wagon; White Knuckle sliders, 315 BFGs, BD 2Lo Kit, AEV ProCal, Airbags/Daystars, Thuren 2.5" King Power Wagon kit w/ Boogie Bumps, Warn SDP6000
Re: Steering Braces
Post by TankerZak » Mon Nov 13, 2017 11:45 pm
I drove my truck about 60 miles today. This steering brace is night and day improvement. Steering is so much firmer and smoother. Its far and away much more than i expected. If i woulda know itd be this good i woulda done it a year ago.
