2016 Power Wagon.
voodoochilde
2016 Power Wagon.
Post by voodoochilde » Tue Sep 19, 2017 6:38 pm
So, I have read tire thread after tire thread.....maybe I am missing something, but I can't seem to tell what can be ran on my truck. I am going to be buying aftermarket rims, but have a few questions. Do 35's and 37's work with aftermarket rims? Do they require any mods to work? What offset do I need to get them to work? I have been looking at 12.5 inch wide tires. Thank you for any help in advance. :D
Re: 2016 Power Wagon.
Post by DamageWagon » Wed Sep 20, 2017 1:49 am
Ignore tire threads unless someone is running the exact combo you want. I'd suggest you read the tech section regarding tire and wheel fitment on:
thurenfabrication.com
rkgzx9leftcoast
Post by rkgzx9leftcoast » Wed Sep 20, 2017 12:50 pm
I have a 2016 tradesman. All I can post is my experience, I know others on here have run 35 and 37`s the same as me. I have 37 Ridge Grapplers, they measure a little over 36 on the truck (tire pressure will effect this) on MY truck I have run them on stock suspension with Stock Rims, only rubbed on radius arms on U-turn type turns. I now have Thuren 1.5 level on front. I ran the same tires/rims - only rub on Radius arm on U-turn type turns. rest was fine
I have now switched to method Standards 17 inch X 5.75 or +18 back space. This moved the tire out about 1/2 to 3/4 of an inch , but is still tucked in under flare. I have no rub what so ever now. It seems to have moved the rim/tire away from the radius arm. I never had to trim plastic liner, or Pinch weld that some say they have to, even stock.
I have been off road with the truck, but havnt had anyone that could stand outside and see if it was rubbing anywhere while stuffing into wheel well. I havnt seen any visible marks on truck or tires!!
I know the Toyo R/T is similar in size from what others have posted on here. The Toyo M/T has more lug on the side of it, a few people running them as well, but you may have more interference with them. On the rims Aftermarket and tire interference, it will really depend on offset. I know I looked on line a lot before I pulled the trigger. there are some off road shops who have good info and have done a lot of Rams like CJC off road( most Diesels), but have a lot of experience with off road rims, and 37`s
rkgzx9leftcoast
Post by rkgzx9leftcoast » Wed Sep 20, 2017 12:53 pm
Sorry I missed a few things . My Tires are 37 X 12.5 x 17 . and My Method standards are 17 X 8,5 wide with a 5.75 or +18 backspace
Post by TankerZak » Thu Sep 21, 2017 12:01 am
I run Toyo RT 35/12.5R17 on a 2016 Laramie. Stock rims, no modifications to height, etc., no rubbing with the same tire in factory spare location (deflated to 20psi). And carry onboard air. I've never heard a single rub. Stock rims are really hard to replace. They have a lip in them so you can run low pressure. Hard to find on the market. You'll basically be downgrading function for looks. To each their own, just an FYI.
2016 Granite Crystal Metallic Power Wagon Laramie, graphics delete, debadged, Thuren front and rear coils, Thuren rear swaybar links, Thuren front and rear trackbars, Traxada rear 1 inch spacers, King 3.0 (Stage 4) front and 2.5 (Stage 3) rear shocks, Boogie front bump stops, Cooper STT Pro 37x13.50R17 on XD Machette 17x9 +18 wheels, Centramatics, DOR steering brace, Thuren King Steering Damper, Synergy Steering Kit, Thuren PW bumper, White Knuckle rock sliders, Dethloff skid plate, Purple Cranium Half Spider front and rear diff guards, Airlift 5000 Ultimate airbags with Daystar cradles, Bakflip Revolver X2 tonneau, AMP BedStep, Factor55 Ultrahook with 100ft 7/16 A.R.E. Spidersilk synthetic winch line, Zroadz Grill with slim 20 inch light bar, DDM Tuning LEDs/HIDs, Magnaflow 19200 modified with upgraded resonator and after axle dump, tinted front windows 35%.
Hammerballs
Post by Hammerballs » Thu Sep 21, 2017 12:02 pm
That's is exactly the problem replacing stock wheels. Also the fact that most aftermarket wheels are cast instead of forged. I really want my wheels to be black though. Have heard mixed opinions on whether or not it is ok to powder coat our stock forged wheels.
2016 Laramie Power Wagon
Post by olyelr » Thu Sep 21, 2017 4:17 pm
The biggest issue with the stock wheels (setting aesthetics aside) is they have a bit too much backspacing.
Also, this super magical interior bead holder thingamajigy certainly does not look any more impressive than any other wheel I have seen. I personally do not bank on that all that much.
Hammerballs
Post by Hammerballs » Fri Sep 22, 2017 12:31 am
How much "better" do you consider the stock wheels being forged compared to a quality cast aftermarket wheel?
Shaved Ice
Post by Shaved Ice » Fri Sep 22, 2017 8:55 am
From this website (steel, not aluminum, but the principles should hold true):http://www.atcgroup.com.au/customcastin ... rging.aspx
Forged steel is generally stronger and more reliable than castings and plate steel due to the fact that the grain flows of the steel are altered, conforming to the shape of the part.
The advantages of forging include:
Generally tougher than alternatives
Will handle impact better than castings
The nature of forging excludes the occurence of porosity, shrinkage, cavities and cold pour issues.
The tight grain structure of forgings making it mechanically strong. There is less need for expensive alloys to attain high strength components.
2017 Power Wagon
Laramie
Rambox
2007 Power Wagon (sold)
Rodeoflyer
Post by Rodeoflyer » Fri Sep 22, 2017 10:16 am
Post by TankerZak » Mon Sep 25, 2017 12:43 am
Hammerballs wrote:That's is exactly the problem replacing stock wheels. Also the fact that most aftermarket wheels are cast instead of forged. I really want my wheels to be black though. Have heard mixed opinions on whether or not it is ok to powder coat our stock forged wheels.
Maybe just get wheels from a 2017? They would be black. The backspacing only matters if you want to go larger than 35s. I didn't because i wasn't willing to give up towing and full size spare in stock location.
Hammerballs
Post by Hammerballs » Mon Sep 25, 2017 2:45 pm
That's my issue. I want 37s. I don't tow heavy or frequently.
Hammerballs
Post by Hammerballs » Mon Sep 25, 2017 2:46 pm
Unfortunately I want to go to 37s so the decision isn't quite that simple.
