Coolant Leak?
Coolant Leak?
Been seeing coolant dripping randomly on the right radius arm/ground since I purchased the '17 Power Wagon a couple months ago. I peeled back the plastic flap underneath the right wheel well and found that the liquid was simply dripping out of a plastic tube about an inch long (coolant overflow?). Unfortunately I was unable to squeeze my camera under there to take a picture. Is is the common occurrence or is it worth further investigation? Thanks.
'17 Power Wagon
35" Yokohama Geolander G003
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
-Rear sway bar links
-King steering damper
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
Re: Coolant Leak?
If the tube is on or near the firewall. That would be moisture dripping from the a/c evaporator. Nothing to worry about. The amount that comes out is determined by the humidity in the air. What you can do. Is put your finger in the puddle and see if it's just water or anti-freeze.
Your coolant over-flow is on the coolant reservoir mounted on the radiator.
Re: Coolant Leak?
I had a feeling it had something to do with the A/C, cuz I've dipped my finger in there numerous times and each time it looked and felt like water with no odor. Thanks Rusty!
'17 Power Wagon
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
Re: Coolant Leak?
Re: Coolant Leak?
I'm sure that's what he's seeing, but the coolant tank on the newer trucks is on the passenger side of the firewall.RustyPW wrote:If the tube is on or near the firewall. That would be moisture dripping from the a/c evaporator. Nothing to worry about. The amount that comes out is determined by the humidity in the air. What you can do. Is put your finger in the puddle and see if it's just water or anti-freeze.
Re: Coolant Leak?
I haven't been under the hood on the newer trucks yet.waldo wrote:I'm sure that's what he's seeing, but the coolant tank on the newer trucks is on the passenger side of the firewall.RustyPW wrote:If the tube is on or near the firewall. That would be moisture dripping from the a/c evaporator. Nothing to worry about. The amount that comes out is determined by the humidity in the air. What you can do. Is put your finger in the puddle and see if it's just water or anti-freeze.
