Page 1 of 2
17 dual alternator install
Posted: Sun Sep 10, 2017 9:48 pm
by HeavyDuty
So I ended up getting everything I wanted on my wagon except for dual alternators. Does anyone know what's involved with installing dual alternators?
Re: 17 dual alternator install
Posted: Sun Sep 10, 2017 10:10 pm
by FordyceCreekTrail
Are there any aftermarket kits? You could see what the parts cost from the Stealer, but I bet its a hell of lot more then the 395.00 upgrade cost. Obviously you need some brackets and a different belt, the real question is what you have to do with the wiring. I can check mine out when it gets here. But thats 6-7 weeks.
Posted: Mon Sep 11, 2017 12:28 am
by HeavyDuty
I have done some looking and am not finding much. I was hoping another member had done or researched this. I'm hoping all it entails is a bracket, alternator, belt, and harness.
Posted: Mon Sep 11, 2017 6:53 am
by olyelr
HeavyDuty wrote:I have done some looking and am not finding much. I was hoping another member had done or researched this. I'm hoping all it entails is a bracket, alternator, belt, and harness.
Yea, thats pretty much it. I think you have to reflash computer too? Check reloaderguy's build page, I am pretty sure he has some info in there about it as he was looking into it as well. Wanna say it was around $750 worth of parts.
Posted: Mon Sep 11, 2017 9:55 am
by OffroadTreks
Reloaderguy wrote:For anyone interested, I've been working with Benny at All Mopar Parts to source the OE parts necessary to upgrade to factory dual alternators. The option is $400 when ordered from the factory. Based on the parts needed it looks like about a $700 upgrade aftermarket. This should be the same for all 2015-2017 Power Wagons as long as you have the factory 220A alternator option. Diesel guys have done this upgrade and said it is fairly simple and only requires a dealer to add the correct sales code (XF5 for gas trucks).
Here is a link with the parts breakdown: http://www.ramforum.com/f133/ram_2500_3 ... tor-80399/
azracer wrote:XF5 Alternator 56029643AB
Bolts for XF5 Alternator 6102172AA x3
Crankshaft Damper 4893285AA
Waterpump tube with XF5 option 4893371AC
Heater supply and return hoses 68252175AA
Harness is part of transmission wiring 68268429AD (For use with DK3 Shift on the fly t-case option)
Harness is part of transmission wiring 68268427AD (For use with DK1 Manual t-case option)
Belt for Aux Alternator 68232297AA
Alternator Bracket 4627648AC
Posted: Mon Sep 11, 2017 6:04 pm
by TwinStick
Not too bad of a price, considering the cost of this one ( https://www.dcpowerinc.com/fit/Dodge~Ra ... 70-xp.html ) & it is 110 amps less than the 2 together.
Posted: Mon Sep 11, 2017 7:53 pm
by Colibri
TwinStick wrote:Not too bad of a price, considering the cost of this one ( https://www.dcpowerinc.com/fit/Dodge~Ra ... 70-xp.html ) & it is 110 amps less than the 2 together.
That's the one I've been running for a few years now, I've always been happy with it but I'd love if there was a dual alternator option for the 5.7's
Posted: Mon Sep 11, 2017 10:00 pm
by TwinStick
Yup, I'm running that one too. No complaints, but I too wish they had dual alt's on the 5.7.
Posted: Thu Nov 30, 2017 3:41 am
by TankerZak
I'm in this same boat. I got everything except dual alternators. It's next thing on my list. Did we land on a resolution? I was going to just go ask the dealer if they could convert it. Not sure what they'll say but i like to go in with some information.
Posted: Thu Nov 30, 2017 9:45 pm
by TankerZak
Dealer is calling me back tomorrow to see what they can figure out...
Posted: Fri Dec 01, 2017 11:08 am
by OffroadTreks
Dual battery setup and a high amp alternator is a bit cheaper and a faster install time. ;)
Posted: Fri Dec 01, 2017 1:09 pm
by DamageWagon
I'm with Mike. A good, serious duty alternator would beat dualsnin my mind. I would rather have a single good component than two okay components, particularly when it comes to batteries. Otherwise when one starts to go it commonly kills the other too. If you need more amps when winching just idle up with your foot. I would have loved more juice the last few times I was winching trees, but I'd never pay even the cost of a second battery to get it. Hundreds or thousands of dollars isn't worth ten minutes of my time when using a slower winch.
Posted: Fri Dec 01, 2017 6:01 pm
I would go upgraded alternator if I was not getting duals on my new truck. Extra battery is really heavy, upgrading the alternator is easy, however expensive. My trail rig does great with a bigger alternator and one battery.
But if your ordering new....FOR THE LOVE OF GOD CHECK THAT 295.00 BOX!
Posted: Fri Dec 01, 2017 7:41 pm
by TankerZak
I didn't order. Lucked across my exact truck, even color, without dual alternators. I did get a few things I didnt necessarily want, cargo camera, adjustable pedals, push button start. Not against any of those extras, just wasn't on my list and i don't find them necessary.
Dealer says the upgrade to dual alternators isn't possible... to much change in wiring. I actually don't believe the answer...
Posted: Sat Dec 02, 2017 8:28 am
Sounds like a typical dealer. In other words they don't want to bother and don't have the talent to run some wires.
Posted: Sat Dec 02, 2017 11:25 am
by TankerZak
That was my interpretation of it as well...
Posted: Sat Dec 02, 2017 12:32 pm
by olyelr
Yes. All the parts can be purchased from mopar, installed, and get the computer reflashed and wallah.
Posted: Sat Dec 02, 2017 5:46 pm
by TankerZak
Anyone done it though?
Posted: Sun Dec 03, 2017 3:24 pm
by KevinABQ
Diesel guys have done it. The serpentine belt is a bitch on their trucks.
http://www.cumminsforum.com/forum/2013- ... 4-ctd.html
Posted: Sun Dec 03, 2017 8:53 pm
by Reloaderguy
A higher output aftermarket alternator is less expensive and will have less parasitic power draw on the accessory pulleys.
Posted: Sun Dec 03, 2017 10:37 pm
by TankerZak
You happen to know the highest amperage aftermarket alternator? Can it get near 380A? Do you still have to flash the computer?
Posted: Sun Dec 03, 2017 11:29 pm
by Reloaderguy
Posted: Mon Dec 04, 2017 12:34 pm
by TankerZak
Looks like you can go upnto 320Amp on a single alt. Kinda makes dual alts redundant (ha!). Anyone know the difference between Idle Amp and Max? I'm guessing Idle is at idle and Max is with the engine revving hard. I think i have the 180Amp OEM but i don't know if thats at idle or max...
Posted: Mon Dec 04, 2017 12:39 pm
by OffroadTreks
$750.00 Pft.
If you know a good alternator & starter shop, they can usually rebuild/upgrade them to a higher output using a kit for half that cost. We had a place in Tampa that I used that rebuilt my 180 on our Trailblazer to a 260 unit. Cost me under $200
Or get a kit and do it youself.
Posted: Mon Dec 04, 2017 3:20 pm
by TankerZak
Hmmmm, not sure what i want to do on a truck under warranty...
