Board index General Power Wagon Talk
Hypertech
Postby Z's2016PW » Thu Jul 13, 2017 6:46 pm
Okay, I just received my Hypertech speedometer calibrator. Install was extremely easy. Haven't had a chance to verify the speedo yet, but I will within the next couple of days. The nice thing about this piece of equipment is if Hypertech ever comes out with a tune for our engine it can be upgraded to the max energy. Before I forget the part number for our trucks is 752501.
Z's2016PW
Re: Hypertech
Postby Z's2016PW » Fri Jul 14, 2017 12:23 pm
Had a chance to drive the Wagon today. It feels like stock again. Throttle response is normal and so is the downhill speed holding. Transmission seems to be shifting smoother. Overall I would say that this is a very worthwhile mod. I don't think it matters which brand of tuner you go with just do it!
Z's2016PW
Re: Hypertech
Postby coder » Fri Jul 14, 2017 7:59 pm
It definitely helps with drivability for sure. A good test to see if it's dialed-in correctly is to get a free GPS Speedometer app on your phone, take a drive and compare it to you truck at a steady 65 MPH it should be within 1 MPH I actually had to adjust mine a couple times to get is to match.
Steering/Drivetrain/Axles: Carli Front Diff Guard | Dynatrac Ball Joints | Redhead Steering Gear
Re: Hypertech
Postby Chromolykid » Sat Jul 15, 2017 2:16 pm
Are these a one shot per VIN deal or could I buy a used one? Ebay has some for $50 occasionally.
Chromolykid
Re: Hypertech
Postby Z's2016PW » Sat Jul 15, 2017 6:56 pm
I did not have to put the vin in so it is possible that you could buy a used one for your wagon.
Z's2016PW
Re: Hypertech
Postby Z's2016PW » Sat Jul 15, 2017 6:59 pm
The other nice thing about this calibrator is that it will read and clear dtc's.
Z's2016PW
Re: Hypertech
Postby coder » Sun Jul 16, 2017 6:18 pm
I believe it automatically reads the VIN from computer during the first use and locks it, but I have never tested it.
Re: Hypertech
Postby Timgco » Mon Jul 17, 2017 11:40 pm
These do vin lock. You can switch vehicles, but do have to pull the settings back out and out back to stock.
2016 Laramie Power Wagon
...www.idontworkforaev.com...
Timgco
Return to Power Wagon Talk
Who is online
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 5 guests
cron
