2013 PW with 2" Mopar level, and 35x12.50?
Cdhetzel
Post by Cdhetzel » Tue Jul 04, 2017 4:54 am
What's up everyone?! Ok, so I have a 2013 wagon that is bone stock, at the moment. I just ordered the 2" level from Mopar and was wondering if I could get 35x12.50s on it without rubbing. I know the rim has a lot to do with it based off of searching but what would a good backspace be? Thanks for any and all information guys!
Deano
Re: 2013 PW with 2" Mopar level, and 35x12.50?
Post by olyelr » Tue Jul 04, 2017 8:16 am
You dont need a leveling kit at all to fit 35s, they fit stock. With the stock wheels you will most likely get a little rub on the control arms. No biggy.
2016 Ram Power Wagon Laramie - Granite Crystal Metallic - Ramboxes
- A virgin, other than White Knuckle sliders... and lots of Fluid Film -
Post by DamageWagon » Tue Jul 04, 2017 12:05 pm
This is covered on Thurens website, under the tech section, tire fitment. Check that out. You would benefit from new control arms, otherwise expect a little rub and maybe a slight decrease in turning radius. Rear axle is no problem. I didn't even know Mopar made a leveling kit. It fits the Wagons?
Stickman
Post by Stickman » Tue Jul 04, 2017 5:49 pm
I've got a '12 with the Mopar 2" level and I'm clearing 37x12.5x20s on 20x9 -12mm offset rims and only had to trim the rear of the front fenders (pinch weld, innner fender, fender flare) 35s shouldn't be an issue.
Cdhetzel
Post by Cdhetzel » Mon Jul 17, 2017 11:03 am
Well, I should have it all installed tomorrow, so I will let you know how it works out and post pics of how she looks!
