I'm sure this has been asked before. But my search came up with nothing
When I steer my 17 power wagon as sharp as I can the front end kind of twists up funny and you can almost hear the front tires scrubbing. It also seems like one tire hits a stop. And the other goes a bit more.
Again, this is my first ram but the way it steers sometimes feels almost like 4wd
Thanks in advance for the help.
17 Power Wagon steer issue
“ROCKY MOUNTAIN” TESTED
Re: 17 Power Wagon steer issue
The tires will scrub a bit in full lock turns. You sure it's not a little ABS/traction control chirp and not PS noise? My 16 will do it when making some specific kind of slow, sharp, off camber turns. Even on asphalt.
Kind of hard to explain, but there's a few places I turn into/out of in hilly WV where the truck will do it every time.
2007 and 2019 Power Wagons
I seem to hear a scrubbing even at lower speeds. You think it's coming from the rear and the anti slip rear ended?. The front end still baffles me. It just doesn't make much sense.
Had to say from across the internet. Know anyone else local with a PW of the same gen that you can drive?HeavyDuty wrote:I seem to hear a scrubbing even at lower speeds. You think it's coming from the rear and the anti slip rear ended?. The front end still baffles me. It just doesn't make much sense.
The limited slip portion of the diff is pretty much a torsen type and they aren't really prone to chattering. That's not to say that you're not going to notice when you're taking a hairpin turn going uphill on a gravel road and one of the rear wheels unloads. That happens more often on the leaf spring trucks though from my experience.
BTW, there are no clutches so don't think about adding a friction modifier to the diff fluid.
I always assumed it is because the front tires don't stay flat on the pavement as you turn the steering. The weight of the front in is now on the edges of the tires. I believe this is what causes the scrubbing sound you refer to.
If you turn your steering wheel (either direction) until it stops, put in in park, and get out of the truck to look at the tire, you will see what I am talking about.
2017 Power Wagon
Laramie
Granite Crystal Metallic
Rambox
2007 Power Wagon (sold)
Laramie
Rambox
Mine does the same in super tight turns. I'm not worried about it. It steers real well otherwise.
2016 RAM 2500 Power Wagon SLT
NR6E
NR6E
There are a bunch of threads on other forums discussing friction modifiers added to Ram limited slip rear ends. Most users claim quieter and smoother rear ends, regardless of no clutches. Also, since disconnecting the front sway bar I can feel all of the rear end's quirks; chatter, tire lift, torque steer, etc. The truck's weight, long wheel base, and heavy front sway bar hide most of what the rear end is doing in a stock truck.waldo wrote:Had to say from across the internet. Know anyone else local with a PW of the same gen that you can drive?HeavyDuty wrote:I seem to hear a scrubbing even at lower speeds. You think it's coming from the rear and the anti slip rear ended?. The front end still baffles me. It just doesn't make much sense.
TL;DR If you haven't added friction modifier go ahead and add some and see if it resolves your issues. It won't hurt anything and the worst case scenario is your wallet gets a little lighter.
ETA: if what you're feeling is at full steering lock that's probably not the rear end.
