Need CAD unit wiring diagram.
waldo
Model Year: 2019
Post by waldo » Tue Jun 13, 2017 12:44 pm
I need to see if there is some positioning feedback wiring going back to some module or other.
I keep getting random 4WD shift in progress messages on the EVIC. Naturally the dealer can't duplicate it because it's random.
My guess is that it's not 100% in the disengaged position since it stops if you put it in and out of 4H.
2007 and 2019 Power Wagons
Pit Slave
Re: Need CAD unit wiring diagram.
Post by Pit Slave » Tue Jun 13, 2017 12:46 pm
There should be a sensor of some sort to create the feedback loop, telling whether it is engaged or not.
Post by DamageWagon » Thu Jun 15, 2017 12:34 am
BLM... If you ever leave us we will all return to the Stone Age...
Post by DamageWagon » Thu Jun 15, 2017 11:42 am
waldo
Model Year: 2019
Post by waldo » Mon Jun 19, 2017 6:13 pm
Update. Had the truck in for the trans recall and had them look at this issue while it was there. They found the drive train control module was bad. Last time I had them look it didn't have any stored codes, this time it did. Should be fixed now.
Post by olyelr » Mon Jun 19, 2017 7:11 pm
So this is for a newer wagon then ('14+)?
waldo
Model Year: 2019
Post by waldo » Mon Jun 19, 2017 7:30 pm
olyelr wrote:So this is for a newer wagon then ('14+)?
My 16, my 07 doesn't have all that garbage.
From what I gather, the module was sending out the wrong/bad voltage to a bunch of sensors it looks at.
It's been doing that on and off since it was new and it just didn't set any codes until recently.
NickTF
Post by NickTF » Tue Jun 20, 2017 8:49 am
Is anyone making a manual CAD engagement option for our trucks like those which exist for the older 2nd gen rams? My truck is a 2015 and it would be nice to have 2wd lo when at a boat ramp in the future.
Post by olyelr » Tue Jun 20, 2017 2:26 pm
NickTF wrote:Is anyone making a manual CAD engagement option for our trucks like those which exist for the older 2nd gen rams? My truck is a 2015 and it would be nice to have 2wd lo when at a boat ramp in the future.
I have not seen a manual CAD kit for the new trucks yet, but they do have an electronic setup that makes the CAD not engage when putting it in 2 low.
Here is a thread I started a bit back about it, with a link to the kit...
http://forum.powerwagonregistry.org/vie ... kit#p76265
NickTF
Post by NickTF » Tue Jun 20, 2017 2:40 pm
^^^^buuuuuuTTTTTTfuuuuuul, thanks!
