Surprise Discovery
Surprise Discovery
Post by OffroadTreks » Mon Jun 05, 2017 11:25 am
So, decided to change the oil and the difs and well.... noticed this. :jawdrop:
Re: Surprise Discovery
Post by nts007 » Mon Jun 05, 2017 11:30 am
custom exhaust tuning right there. And increased oil cooling capacity :lol:
Post by OffroadTreks » Mon Jun 05, 2017 11:35 am
That's the transmission pan and man is it dented.
rkgzx9leftcoast
Post by rkgzx9leftcoast » Mon Jun 05, 2017 11:56 am
That Sucks !!! looks like a pan swap or bang out dent is in the works??
flattire
Post by flattire » Mon Jun 05, 2017 12:26 pm
Any leaking from the pan? Looks like it took a good hit.
Filter damage inside?
Would be a good time to have a drain plug....but we don't.
Wonder if a Mag-Hytec would have cracked....or chipped the rock.
Post by coder » Mon Jun 05, 2017 2:11 pm
Definitely want to drop the pan and see if anything was damaged inside, an aftermarket cast aluminum pan would have cracked I bet.
13BlkPowerWagon
Post by 13BlkPowerWagon » Mon Jun 05, 2017 4:10 pm
Time for a skid plate there for sure!
Rodeoflyer
Post by Rodeoflyer » Mon Jun 05, 2017 4:39 pm
My filtermag would have deflected that
Post by Colibri » Mon Jun 05, 2017 4:44 pm
I've done the same thing, which is why I won't run a cast pan until I get around to skid plating that area. Just drill a small hole to drain it and either bang that pan back into shape and put a drain plug bung where you drilled the hole or get a new pan. If you've smacked it once you'll smack it again.
Post by olyelr » Mon Jun 05, 2017 5:11 pm
What did you do, run up over a tall curb at Starbucks?
Post by OffroadTreks » Mon Jun 05, 2017 6:04 pm
olyelr wrote:What did you do, run up over a tall curb at Starbucks?
I drive there a lot.
Post by RustyPW » Mon Jun 05, 2017 6:07 pm
Looks like you're been rock munchin'. :lol:
Post by olyelr » Mon Jun 05, 2017 7:42 pm
Thats why I stay the hell away from that place... get ya every time!
When I go wheeling I stick to the mall or the Dairy Queen :rockon:
On a serious note, I cant hardly believe that pan isnt seeping a little bit :shock:
Post by Bill2014 » Mon Jun 05, 2017 8:56 pm
You been jacking that truck up using the transmission pan??? :poke:
Post by Reloaderguy » Mon Jun 05, 2017 9:25 pm
Sad little low rider.
agpilot
Post by agpilot » Mon Jun 05, 2017 10:59 pm
Well this must make the decisions to go to 37s a little easier :)
Post by TwinStick » Tue Jun 06, 2017 2:42 pm
:lol: You guys are brutal ! :lol:
Post by OffroadTreks » Tue Jun 06, 2017 2:46 pm
Banged it out with a hammer.
Post by RustyPW » Tue Jun 06, 2017 3:10 pm
MikeKey wrote:Banged it out with a hammer.
So..........you had sex with it. You banged it. :lol:
Post by olyelr » Tue Jun 06, 2017 5:29 pm
Its fun to have sex with a hammer every now and then.
Post by OffroadTreks » Tue Jun 06, 2017 7:28 pm
Every now and then you just gotta hammer one out.
Pit Slave
Post by Pit Slave » Tue Jun 06, 2017 8:50 pm
I think the term is "Every now and then, you just gotta 'bang' one out!"
Post by DamageWagon » Tue Jun 06, 2017 9:28 pm
Pit Slave wrote:
MikeKey wrote:
RustyPW wrote: So..........you had sex with it. You banged it. :lol:
Since we're on the topic of transmissions i guess you would know...
lol
Post by OffroadTreks » Tue Jun 06, 2017 10:10 pm
Pounding it out isn't as fun as hammering it out. You gotta really get in there and go at it.
Post by RustyPW » Wed Jun 07, 2017 12:42 am
Who's in for sloppy seconds? :o
