Taking care of underbody rust...
Got a 2011 PW. Living in the northeast its got some surface rust going on underneath.
Q- Whats the best procedure/product to use to stop it from rusting any further?
Re: Taking care of underbody rust...
Uh oh... I believe TwinStick can answer this one.
TwinStick...you have the answer?
Screw you guys !
I just sold my sons 2004 Toyota Corolla, 191,000 miles & 14 yrs of NY State salt winters, for $1500. This is what the engine compartment looked like, after I cleaned it but before I re applied new FFilm today. Keep in mind, it went 5 winters before I used the Fluid Film on/in it. Underbody is rusty though, but has not rusted much more since using FF.
Say what you want, can't argue with the results.
Any pictures after you applied the fluid film?
I'd like to see what the protected engine compartment looks like
My receipe for rust protection is wire wheel and welder brush the rust, apply rust converter then paint or black rocker guard then undercoat. I use proform undercoating and its been doing great. Costs 80$ for 5 gal istead of 80 for a gallon of fluid film... I live in nasty Nova-Scotia arguably the worst climate for vehicle corrosion issues. Key is to pay attention to where the same vehicles as yours have trouble areas and adress it somehow. the rear wheel well area on our trucks by example i reach by removing the tail lights then pressure wash and undercoat the shit out if it. Its a pain in the ass and i spend about a week of evenings in the fall doing my corrosion control procedure. Sucks but maintaining a rust bucket is way worse
Fluid Film is $40.00 a gallon & $180.00 for 5 gal. And, it has 1001 uses. Can use it on wood, aluminum, steel, etc. It lubricates, penetrates & protects long term. Prevents corrosion between dissimilar metals. Hell, you can even use it to soften & preserve a baseball glove or leather work boots. Bee's & wasps & ants can't stand the stuff. Problem with birds, shitting on your mirrors/truck ? Put some FF on a rag & wipe down the spot they stand on & the birds go away. ALL OF MY NEIGHBORS have nice white shit streaks on their vehicle mirrors & down the sides of their vehicles......but not me. I use it on my snow blower before storing, lawnmower underside before storing. Also prevents battery corrosion. Does not conduct electricity, so it can be used as a dielectric grease.Bill2014 wrote:Any pictures after you applied the fluid film?
Stand by......................................
Shock/strut towers looking like brand new ! ^^^^^^^^^^^^^^^^^^^^^^^
^^^^^^^^^^^Brake distribution, looking like brand new !
This is the hood without being cleaned. ^^^^^^^^^^^^^^^^^^^^^^^. So, the down side is, dirt sticks to it. But if that really bothers you, you can wash it off & start again. Hot water, by itself will take it off. De greaser helps make it faster. Also, it is bio friendly, as it is made from lanolin, or sheeps wool oil. Same stuff found in your wifes make-up.
You certainly can't argue with the results.
Spike and Twin...thanks for the replys.
Q- With FF Do I have to wire brush the existing surface rust offfirst before applying?
You don't have to but the results would be better if you did. If you have lots of time & lots of patients, you could wire brush, coat with a rust converter https://www.theruststore.com/Rust-Conve ... DQod4s4HDQ , or POR 15 http://www.por15.com/POR-15_Rust_Preventive_Coating and then Fluid Film it. I have pondered this for some time, now that I am retired, I have LOTS of time, so maybe down the road I may do my axles like that, IDK.
So you don't just put a film on - you soak it until it starts running off.
Not exactly, but i give it a good soaking. It does certainly drip out of the weep holes in the body though. See, most shops just give it a wicked fast mist. Thats why they say you have to come back every year for re application. The only places i do more than once is the wheel wells, & the axles.I do it till it drips, that way, I know there is plenty in there & everything is covered good. Stay away from the brakes, obviously. Park it in gravel or in the street for a few days after treatment if you have a nice driveway. It does drip, especially when the temps hit 90+.
We picked up my sons first new car today. They offered it (the undercoating) so cheap, I had them do it. They used Fluid Film too. But it was so thin & fine, I could barely tell they even did it. They must have had their spray gun set on CHEAP ASS mode. As soon as he got it home, I re did under the hood. I used a 1/3 of a quart just under the hood. I will redo the rest of the car next time he comes to visit, in a month or 2. Inside the body, doors hood, hatch back, rockers, A pillars, B pillars, etc. I have all the flexible wands, 360* mist, straight aluminum one, flexible ext for spray cans, adjustable gun. I also have the 1/2" drill & body plugs to put in the holes afterwards. My daughter hated the Fluid Film at first, but now that she is working & sees how fast money goes out to pay bills, she likes the idea of NOT seeing her only means of transportation rust away right before her eyes. I just wish I knew about this stuff when I was young. I am SURE i would have had have at LEAST 2 less vehicles, if not more.
The Pro set up gun with every accessory.
http://www.kellsportproducts.com/undercoatingguns.html
DO NOT waste your money on the $36.50 gun like i did. It sucks beyond belief. I also have 5 of the quart screw on the gun containers. Money well spent so you don't have to stop & refill when doing vehicles.
Hey 2Sticky. Can you use Fluid Film as anal lube?
Probably. It's all natural.
What do the inmates use?TwinStick wrote:Not sure. Check that out for us will ya ?
- Thread Detour.jpg (17.15 KiB) Viewed 2888 times
I don't see application of fluid film on the inmate's list:RustyPW wrote:What do the inmates use?TwinStick wrote:Not sure. Check that out for us will ya ?
apply lip gloss – bash the bishop – bate – beat it – beat off – beat (one's) meat – beat the bishop – beat the kids – bop the bishop – buck the slobbering donkey – choke (one's) chicken – choke the chicken – cook up a batch – crack one off – date Miss Michigan – date Mrs. Palmer – double-click (one's) mouse – drop the kids off at the pool – fap – five knuckle shuffle – flick (one's) bean – flick the bean – flog (one's) log – flog the bishop – flog the log – frig – go to the bank – have a date with Rosey Palmer – have a date with Rosey Palmer and her five sisters – have a tug of war with Cyclops – have a wank – have sex with (one's self) – hump (one's) fist – jack off – jerk it – jerk off – jerk (one's) gherkin – jerk the gherkin – jerk the johnson – jill off – junior Olympic pole vaulting – kill a kitten – master debater – paint the ceiling – pet (one's) kitty – pet the bunny – play pocket pinball – play with (one's self) – pluck (one's) twanger – plunk (one's) twanger – polish (one's) knob – polish (one's) pearl – polish the family jewels – polish the pearl – pound (one's) pud – pudwhack – pud wrestle – pull (one's) pud – pull the pud – punch (one's) clown – punch the clown – punch the munchkin – punish percy – rough up the suspect – rub one off – rub one out – self-abuse – self-love – sex with someone you love – shake the creamer – shlick – skin off – slap the salami – smack Lester – snap – spank – spank bank – spank it – spank (one's) monkey – spank the monkey – stranger – stranger, the – stroke it – stroke (one's) salami – stroke the salami – torque it – toss – tosser – toss off – tribute picture – wack off – wank – wanker – wank it – wank off – wax the carrot – wax the dolphin – whack it – whack off – yank it
