Thuren 2" or 3" coils?
aheiser
Post by aheiser » Wed Apr 19, 2017 8:23 am
I'm almost ready to complete the suspension and ditch the puny tires on my 2012. This forum has been a huge source of info. Like many folks, because of towing, spare tires, etc. I think I'm going to stick with 35s for a few years, probably Toyo MTs. I already have the thuren arms, track bar and shocks. Just need the coils. I like the slightly positive rake on the truck. It sounds like 2" springs would provide ample clearance for 35s and just barely level it out? 3" would be plenty of lift and help with 37s in the future though I'd almost certainly need a shackle lift to put the back up a touch higher? I believe the back does currently sit about 1.5" higher than the front measuring the wheel wells. And of course almost an inch of driver side lean.
Any thoughts before I pull the trigger on this? Thanks!
Re: Thuren 2" or 3" coils?
Post by DamageWagon » Wed Apr 19, 2017 9:04 am
Lifting the front won't do anything for clearing tires. Lift does not help or hurt that at all. Good job getting the other goodies first! I have a 2011 and I put on 3" springs, but this made my front sit dead level or just a touch bigger than the rear. With Thurens lift shackles on the highest setting now my rear sits just a touch higher. If you plan to use his shackles or leaves, I would suggest a 3", but if you plan to leave the rear alone I would suggest a 2", although that really isn't doing anything for your power wagon except giving you a fresh set of springs. It will help your drivers side lean by giving a spring that isn't sagged, but you will always have a little lean on drivers side due to the battery, gas tank and driver loading that side.
jswider
Post by jswider » Wed Apr 19, 2017 7:27 pm
I am in the same dilemma here. I also have a 2012 and am thinking of doing 2 inch coils, overland shocks, and rear air bags with the cradles. Have 35s now and they clear just fine. Next set will be 37s.
Ducky's Dad
Post by Ducky's Dad » Wed Apr 19, 2017 9:08 pm
My '05 leaned on the passenger side, but I have added a lot of stuff on that side, including two house batteries, water tank, Hi-Lift, tool box, etc. When I installed new Carli spring packs in the rear, I still had to use the Firestone air bags to level the truck.
Post by Bill2014 » Thu Apr 20, 2017 5:40 am
Or consider fabbing up an adjustable end link for your rear stabilizer - I've done that for past vehicles and it was cheap and worked great for a side-to-side level. :idea:
Locker Bypass
aheiser
Post by aheiser » Tue Apr 25, 2017 9:46 am
Thanks for the tips! That makes sense. I'm leaning towards trying the 2s. If I recall, in the earlier days Thuren springs yielded quite a bit of lift. I'm think that for 35s, the 2" springs will be a nice refresh and in the event they provide a lot of lift (or my rears having sagged some), I'll just lift the back a hair if need be. If I was imminently going to 37s, I bet the 3" lift and more in the rear would look better.
Post by FirerescuePW » Tue Apr 25, 2017 3:27 pm
Before you settle on the 2s, just know that the Thuren shackles really make a difference in the feel of the rear suspension. It may be worth going to 3". There is an OEM setting as well, if you really don't want the extra height.
aheiser
Post by aheiser » Fri Apr 28, 2017 9:11 am
Interesting! I hadn't heard much about the ride quality of the shackles, only the increased height. Sounds like they'd be valuable to have. I may consider going that route. I'd assume with the 3" coils there's pretty little chance that it lifts it so much that 35s look way too small on it.
Post by Will » Fri Apr 28, 2017 10:11 am
You lost me a 35's... if only 35's, stay where you are and save your money. :lol:
Thuren 3" coils, shackles and 37's on a my 2010...
Post by olyelr » Fri Apr 28, 2017 10:27 am
Nice to see ya back around Will, and that truck of yours still looks kickass!
aheiser
Post by aheiser » Tue May 02, 2017 7:24 am
Ha, thanks Will I hear ya. Out of curiosity (I'm sure you've probably mentioned it elsewhere) but how much lift in front do you think the 3" springs netted you? Quite a bit?
