cat replacement
stamm20
cat replacement
Post by stamm20 » Mon Apr 17, 2017 12:56 pm
I was wondering if anyone has had to change their cats out yet? I need to replace mine and was looking at some of the thunderbolt high flow cats. Any suggestions or advice not looking to spend a ton of money on it.
Re: cat replacement
Post by TwinStick » Mon Apr 17, 2017 5:11 pm
I need a new front pipe with the cats. I can not buy anything in NY except factory part-----@ $900+ dollars !!! :angry: I am waiting as long as possible.
https://www.buymoparpartsnow.com/oem-pa ... dhcw%3D%3D
stamm20
Re: cat replacement
Post by stamm20 » Tue Apr 18, 2017 5:54 am
Yeah I saw that yesterday when I was looking up the specs on piping size
stamm20
Re: cat replacement
Post by stamm20 » Tue Apr 18, 2017 5:55 am
Even tossing around the idea of just cutting em out and trying out those O2 simulators that are for sale on Amazon
Re: cat replacement
Post by TwinStick » Wed Apr 19, 2017 3:48 pm
They would not even accept my truck on a trade in if i removed the cats & 02 sensors ! Gotta love NY.
stamm20
Re: cat replacement
Post by stamm20 » Thu Apr 20, 2017 8:15 am
That's crazy mine might not pass inspection here in NC doing it but it doesn't pass now anyway lol
Re: cat replacement
Post by coder » Sat Apr 22, 2017 7:14 pm
Call a local muffler shop...
Re: cat replacement
Post by RustyPW » Sun Apr 23, 2017 11:31 am
TwinStick wrote:They would not even accept my truck on a trade in if i removed the cats & 02 sensors ! Gotta love NY.
That's almost every state. Can't mess with the emissions equipment. If I sell my Nismo. I would have to put some stuff back on.
Re: cat replacement
Post by TwinStick » Sun Apr 23, 2017 11:36 am
What a PITA that would be.
Re: cat replacement
Post by coder » Sun Apr 23, 2017 4:48 pm
Rockauto has cats for $279 you could have them installed at a local shop not cheap but better than the dealer. Magnaflow also sells them you would need 2.5" input/output to match the factory pipes.
stamm20
Re: cat replacement
Post by stamm20 » Sun Apr 23, 2017 7:30 pm
I ended buying the magnaflow kit comes with everything from manifolds back to the y pipe 400 bucks on ebay
Re: cat replacement
Post by TwinStick » Mon Apr 24, 2017 7:14 am
coder wrote:Rockauto has cats for $279 you could have them installed at a local shop not cheap but better than the dealer. Magnaflow also sells them you would need 2.5" input/output to match the factory pipes.
I wish it was that easy for me. They won't be legal in NY. Has to be OEM till after the cat.
Yup, $295.79 on rockauto . com. But i can't use that one. I have to use the $870.40 one, to be legal in NY.
