Gas caps.......WTF !
Post by TwinStick » Tue Apr 11, 2017 6:11 pm
This is a rant. :rant:
Check engine light came on. P0456. Checked at Auto Zone.
I swear to GOD that the human race is getting dumber. We are not evolving, we are devolving (if that's even a word). I'm sure reloaderguy will chime in & bless us with the answer. So, how f-ing hard is it to design a gas cap that works ? Seeing as how vehicles have been being made for over a century, you would think we would have at least that part of a vehicle down pat by now. But, nope, not even close. I have NEVER had a problem with any gas cap, on any vehicle, until NY State made it a mandatory part of the yearly vehicle inspection. I went through 8 gas caps on my 2000 Dakota in 42,000 miles. 6 on my 2004 Ram 2500 in 26,000 miles. And I am on my 3rd on my 2008 Power Wagon in 45,000 miles. This time, though, I did NOT buy a Genuine Mopar replacement part. I bought one made in China, from Auto Zone. All the others were Genuine Mopar replacement parts. Maybe that was the problem. The Chinese one fits better than a new Mopar one, by far. Seems to seal a LOT tighter as well. Duralast- $10.16 with my discount. $32 @ the dealer. Time will tell if the Chinese got it right.
:rant:
Traded to 2019 ZR2, Red.
MSCH2112
Re: Gas caps.......WTF !
Post by MSCH2112 » Tue Apr 11, 2017 6:49 pm
so new gas cap erased check engine light?
i had the check engine light on along with the check fuel cap light. replaced cap and still had lights soon after clearing codes. turned out it was some emission crap system thing. bogus.
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Post by DamageWagon » Tue Apr 11, 2017 7:02 pm
I had the same thing MSCH, it ended up being my NVLD sensor. Thankfully only $40 for Mopar. Of course this is after I replaced the gas cap.
Sent from my safe space
Post by TwinStick » Tue Apr 11, 2017 7:03 pm
The digital mileage readout said gASCAP when i started it up, about a week before the check engine light came on. That P0456 code has always been the gas cap for me, in all 3 Dodge trucks. I also had 2 of the 02 sensor codes come on in the 2004 once. One before the cat & 1 after the cat, right/pass side. I got some bad gas & had to use about 6 bottles of dry gas, then those 02 sensors codes came up within a day or 2. Took out the 02 sensors, sprayed & wiped/cleaned them with brake cleaner, then sanded them till shiny & reinstalled. No more issues, lights went out.
Where is the NVLD sensor located ?
Post by Reloaderguy » Tue Apr 11, 2017 7:20 pm
That's nothing, you should see the cost of winch rollers.
Post by RustyPW » Tue Apr 11, 2017 7:38 pm
Reloaderguy wrote:That's nothing, you should see the cost of winch rollers.
:rofl:
Post by DamageWagon » Tue Apr 11, 2017 7:41 pm
Hahahahaha. Well if you drill a hole through the old gas caps you could probably stick a bolt through them all and make winch rollers out of them.
The NVLD sensor is the tiny white box that is on the side of the emissions box. Behind the cab on drivers side on the frame rail. It is plugged into a black box.
MSCH2112
Post by MSCH2112 » Wed Apr 12, 2017 12:36 am
DamageWagon wrote:I had the same thing MSCH, it ended up being my NVLD sensor. Thankfully only $40 for Mopar. Of course this is after I replaced the gas cap.
$195 labor and $50 in parts later dealer replaced evap system and vapor canister. did fix the problem and no more christmas tree lights.
mike
Gooseneck
2016 Volvo XC90
waldo
Post by waldo » Wed Apr 12, 2017 8:32 pm
My 07 still has the original gas cap.
2007 and 2016 Power Wagons
MOPARManiac
Post by MOPARManiac » Wed Apr 12, 2017 10:35 pm
Our Durango is always setting that code. After changing out the gas cap, and other parts that cost over a $100 it still sets the code a couple times a month. I ended up just buying a $12 code reader off of Amazon and keep it in the vehicle. I just clear the code whenever it comes on.
Post by ramv » Thu Apr 13, 2017 12:54 am
My second gen Dodge ate gas caps. Of course sliding them on trees and rocks and ripping them off completely may have been the issue. :P
Buy a Chevy I guess, my 2005 was 11.5 years old, had two fuel tanks, got 11 mpg and had 200,000 miles when I sold it and was on the original gas cap.
Someone stole the gas cap off my Ranger so no comment on Ford.
Post by FirerescuePW » Thu Apr 13, 2017 6:47 am
waldo wrote:My 07 still has the original gas cap.
As does my '05...
Post by Will » Thu Apr 13, 2017 7:37 am
Go ahead and buy another gas cap now and put it under the seat, you'll never have another issue. My gas cap was acting up and I bought another one, got busy, forgot about it, never changed it, and that's been probably a year ago and haven't had the problem since. hahaha. I kept getting the actual gas cap is loose light on the dash.
Post by olyelr » Thu Apr 13, 2017 7:56 am
My wifes Denali doesnt even have a gas cap. Maybe GM has the right idea.
11 years and 160 miles with my 2000 Dodge never gave me any gas cap problems or codes.
stamm20
Post by stamm20 » Thu Apr 13, 2017 8:09 am
I get the gas cap message also and the also two different EVAP codes I've tried two different caps one was a aftermarket one and one was a genuine Mopar and neither worked to clear anything lol
Post by TwinStick » Thu Apr 13, 2017 11:26 am
olyelr wrote:My wifes Denali doesnt even have a gas cap. Maybe GM has the right idea.
Like i said, it was NEVER a problem until NY State made it a mandatory part of the yearly inspection. Since then, everyone i know in NY, has had problems with their gas cap, regardless of make or model. Maybe a simple way to charge $30 for a .25 cent part they have made in China ? Even our Made in America Toyota Corolla gas cap has been replaced (1x in 150,000 miles). And yes, I only turn till it clicks one time.
MSCH2112
Post by MSCH2112 » Fri Apr 14, 2017 1:34 pm
Funny our Denali XL doesn't have a cap either. i don't know.....but if something does go wrong i bet gmc has a nice expensive part for it.
mike
Gooseneck
2016 Volvo XC90
Post by TwinStick » Fri Apr 14, 2017 1:49 pm
We used to have a 10 day grace period. So, if it failed, you could bring it home, fix it, & bring it back. Now, the first thing they do before they even start it up, is to scrape off your old inspection sticker, so your screwed if it fails. You are at the shops mercy. If it is emissions related (which the gas cap is, in NY), your vehicle can't leave the shop until it is fixed ! Inspections are like Automobile Mafia, once your in, your in & it seems even when you think your out----they pull you back in ! lol
https://www.youtube.com/watch?v=UneS2Uwc6xw ..................Skip to the .58 sec spot.
Post by Colibri » Fri Apr 14, 2017 7:16 pm
I had an argument with a state inspector a few years ago, he said my gas cap failed and I needed to buy a new one from him for $25 or I wouldn't pass. I asked him if my check engine light was illuminated, he said no, so I asked how it was the Chrysler nvld system didn't detect a gross evap leak and trigger the mil if the cap was bad? He didn't have a good answer lol.
Post by TwinStick » Fri Apr 14, 2017 10:46 pm
Ever since they did that, I feel like I'm being forced by NY State, to do business with "Vinny the loan shark". (in your best Godfather voice) "You are just gonna have to pay." "I got some bad news & some worse news." "Bad news is: it didn't pass & the worse news is.......it's gonna cost you XXXXX to fix it." Sad.
stamm20
Post by stamm20 » Sat Apr 15, 2017 5:52 pm
State inspections are bogus it's a racket for the government NC does them and they try anything they can to fail you
Post by RustyPW » Sat Apr 15, 2017 10:34 pm
I'm glad I live where I do. :lol: No emisions inspections. :lol: BUT if I lived in the next county. I would have to get it inspectioned. :(
Post by DamageWagon » Sat Apr 15, 2017 11:14 pm
I think it's nuts how California is pretty horrible but still much better than the places you guys are talking about. When we go for a smog check, the shop can either do smog, or do repairs, never both. They also don't know jack about what fails you if you do fail, they just tell you it failed and give you a chemical readout of your exhaust that someone can interpret. Then you leave and do whatever you want and come retest. And it makes absolutely no sense to me how we have a massive Mexican population that has a huge tendency to tow way above GCWR, load pickups massively above GVWR, drive on donut tires, half the lugnuts missing, whatever, yet we have no vehicle inspection in the state. If any state ne de inspections it is ours and I am in strong support of it, but for safety reasons exclusively. Go kill yourself in a rickety vehicle, I don't care. But don't kill me because of your cheapness or carelessness.
stamm20
Post by stamm20 » Sun Apr 16, 2017 8:03 am
I would be fine if NC did just safety buy to hook up to the computer and do emission checks and charge you more is just crazy
Shaved Ice
Post by Shaved Ice » Sun Apr 16, 2017 8:38 am
I'd rather drive my nanny laden truck than live in the nanny states some of you are describing. :poke:
2017 Power Wagon
Laramie
Granite Crystal Metallic
Rambox
2007 Power Wagon (sold)
