Hutchinson vs Trail Ready
Kodiak
Post by Kodiak » Sun Mar 19, 2017 10:27 am
Looking to buy some new wheels for my 2016 Laramie Power Wagon. I hope to be able to fit 37x12.5x17 tires with minimal rubbing and I know Thuren recommends a specific offset. I also know that the factory wheels are very high quality, so I want my aftermarket set to also be very high quality.
Between Hutchinson and Trail Ready, which one would you all choose? Or is there another (hopefully less expensive option) that I'm not aware of?
2016 Power Wagon Laramie
Mufflex exhaust
AMP research power steps
RED light bar mount
Bulldog 30" light bar
DD 4300k HID kit
ramv
Re: Hutchinson vs Trail Ready
Post by ramv » Sun Mar 19, 2017 1:06 pm
I would go with Hutchinson. External beadlocks are a pain on daily drivers. I have Allied Rock Monsters on my 2nd gen. Good wheel but a lot more maintenance.
Post by olyelr » Sun Mar 19, 2017 5:53 pm
Hutchinsons are leaps and bounds above trailreadys IMO.
Post by adeluca73 » Mon Mar 20, 2017 7:51 am
Ask Colibri for his opinion--he has Hutchinson's--he speaks very highly of them, and he'd know.
If I ever pull the trigger on new wheels...they are on my list of future mods when I move out West.
2014 Ram PW SLT: Two tone Flame Red & Black
Completed Mods: Ram door sill guards, Front air deflector, WeatherTech slimline window deflectors, DiamondBack HD cover coated w/ Line-X, Mufflex MagnaFlow muffler & Resonator delete, Opti-Coat Pro 2.0, DeeZee tailgate strut, DeeZee ¼" fitted bed mat, Factor-55: FlatLink winch hook/Shorty Strap 3.0/Hitchlink 2.5, Warn Wireless Winch Remote, Locker by-pass, AEM dry filter, Truxedo LED bed lights wired into RamBox Connector, WhiteKnuckle sliders w/ full-length diamond plate coated in Line-X, Purple Cranium rear diff guard, AEV front/rear diff cover, AEV RAI w/ pre-filter, AEV ProCal (Bootleg'd), DOR Steering Box Brace, Phillips Hi intensity LEDs in cargo lamps & back-ups, triple anti-hop shocks, Truxx PW specific front 1.5" level, AAM 4.88's, custom black-out work, Line-X front/rear bumpers & wheel flares, 37" Nitto Ridge Grapplers, Plasti-dip PW wheels Black w/ Gunmetal metalizer, FilterMag kit, AMP Research BedStep
Next Mods: Thuren: {Coils, Track Bar, Boggie Bumps, King 2.5's shocks} , on-board air, HID low CANBUS replacement, LED HI, BD LED fogs
Post by Colibri » Mon Mar 20, 2017 10:15 am
I have hutchinsons on my truck
Trailready on my 1 ton van
Hutchinsons on a Jeep
Spyderlock on another Jeep
All are very high quality wheels, only the hutchinsons are dot approved if it matters to you. They also are basically maintenance free once assembled. All the others you have to keep an eye on bolts. Double beadlock is better than single for gnarly off-road and very low pressures. You can loose an inner bead on other Beadlocks and it usually happens when traversing a steep angle sideways. Any quality Beadlock is good, hutchinsons are great. They do have some drawbacks, mainly cost and weight. A hutchy with a 37" toyo mt has to be close to 140 pounds. You really feel that in accelerating and braking and at the gas pump lol. If you just want a good looking aftermarket wheel don't bother, if you want the functionality of a beadlock the price difference between hutchinsons and trailready is negligible.
Single Beadlocks are lighter but require more attention and it's possible to loose an inner bead
Double are heavy, maintenance free and completely secure
A fella I know was being a hooligan in his lifted ctd and sliding around a dirt corner sideways one tire hit a rock or root and it popped the tire off the bead and flipped the truck on its lid. They're not just for crawling lol
Post by Reloaderguy » Mon Mar 20, 2017 10:39 am
You can't run TPMS sensors in Hutchinsons.
14PowerWaggy
Post by 14PowerWaggy » Mon Mar 20, 2017 10:53 am
They are both great wheels... I love my Trail Readys... They are both expensive but with Hutchinson you get what you get... With Trail Ready you can pick from different sizes, powder coating options, ring sizes and colors, bolt colors etc... My TR's have been on for two years and they look just as good today as they did the day I ordered them (of coarse I did have them clear coated per TR's recommendation)... JMHO...
Post by Colibri » Mon Mar 20, 2017 10:57 am
You can in fact run tpms with hutchinsons, I do on mine. You have to order a separate bracket kit that's a few extra dollars per wheel. Also they have different offsets and backspaces available but nothing over 17" I'm aware off.
Post by adeluca73 » Mon Mar 20, 2017 12:48 pm
Reloaderguy wrote:You can't run TPMS sensors in Hutchinsons.
I don't think that's correct. I'm sure Colibri can verify. See page 6:
http://www.rockmonsterwheels.com/docs/R ... Manual.pdf
Post by Reloaderguy » Mon Mar 20, 2017 12:56 pm
Colibri wrote:You can in fact run tpms with hutchinsons, I do on mine. You have to order a separate bracket kit that's a few extra dollars per wheel. Also they have different offsets and backspaces available but nothing over 17" I'm aware off.
Kodiak
Post by Kodiak » Tue Mar 21, 2017 11:09 am
You can run the TPMS per Hutchinson as well. I just ordered some 37x12.5 toyo RTs, so I do worry about the weight... less about the fuel and more about just feeling too slow.
I bought these cheap wheels for now until I make a decision on the Hutchinsons:
http://www.discounttiredirect.com/direc ... 6&pc=20787
I bought all 5 from the price of one Hutchinson. Hopefully they're not terrible, haha.
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
Post by Bill2014 » Tue Mar 21, 2017 12:23 pm
Kodiak wrote:You can run the TPMS per Hutchinson as well. I just ordered some 37x12.5 toyo RTs, so I do worry about the weight... less about the fuel and more about just feeling too slow.
http://www.discounttiredirect.com/direc ... DQodeI4NZg
Those wheels are "stunning" :wink:
Locker Bypass
Kodiak
Post by Kodiak » Tue Mar 21, 2017 12:45 pm
Haha the description is a bit much, but they're fairly basic attractive wheels I think. I'm not much into the blingy busy looking wheels.
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
bstefanic
Post by bstefanic » Tue Mar 21, 2017 12:51 pm
Did you get 8x170mm lug pattern? Thought that was ford's only
Hella's behind the grill, locker bypass, BDS Long Arm Kit, Carli Front Diff Cover, Rockcrusher Rear, 37" Interco M16's, ATX Cornice Wheels, DT Pro Fab steering box brace, EBC brake pads, Dynatrac Ball Joints, SY Eliminated Transfer Case, Custom Tom Wood's Rear DS, Kings Arsenal Seat Covers, Dynatrac Free Spin Hubs with Dynalocs
Kodiak
Post by Kodiak » Tue Mar 21, 2017 2:51 pm
bstefanic wrote:Did you get 8x170mm lug pattern? Thought that was ford's only
Nah, I posted the wrong link. Link is corrected, I got the 8-165.1mm and the +18mm offset.
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
bstefanic
Post by bstefanic » Tue Mar 21, 2017 3:41 pm
Gotcha just double checking
Kodiak
Post by Kodiak » Tue Mar 21, 2017 4:41 pm
bstefanic wrote:Gotcha just double checking
Yes thank you for that! I would have been sad if I ordered the wrong set, since my tires are already here.
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
rkgzx9leftcoast
Post by rkgzx9leftcoast » Thu Mar 23, 2017 12:37 pm
Those wheels have a nice look to them. I still have the stock wheels, and the they have really grown on me with the 37s on them. I keep going back and forth between keeping these and getting something else, TR, AEV, and a few others.
Will have to post some pics after you get the new wheels n tires mounted !!
Kodiak
Post by Kodiak » Fri Mar 24, 2017 4:59 am
rkgzx9leftcoast wrote:Those wheels have a nice look to them. I still have the stock wheels, and the they have really grown on me with the 37s on them. I keep going back and forth between keeping these and getting something else, TR, AEV, and a few others.
They're on! Some mild rubbing on fender liner and inner aspect of the flare as it wraps around on the bottom, which required minor trimming (which made me sad). No rub on radius arms or sway bar. The wheels actually look surprisingly good in person, I'll get some pics up later today.
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
RAM4ROKS
Post by RAM4ROKS » Fri Mar 24, 2017 11:24 am
I want Hutchinsons so badly!!! It'd be a super heavy wheel and tire combo (Pitbull Rocker Radial XOR LT (backordered right now) on Hutchinsons) BUT, sure would be awesome!!!!
Post by Colibri » Fri Mar 24, 2017 1:40 pm
I've ordered both my sets of hutchinsons through high-impact.net and been well pleased with the level of service. They have more options than rockmonster shows on their website, and can get o-rings tpms brackets and spare parts as well.
