Frames
waldo
Frames
Post by waldo » Sun Mar 19, 2017 6:18 am
I keep reading here and there that the PW has a different frame, but I've also read where it has the same frame as the 2500HD.
Other than some holes and weldments for skid plates and such, what's the truth?
2007 and 2016 Power Wagons
ramv
Re: Frames
Post by ramv » Sun Mar 19, 2017 8:52 am
Has to be generally the same frame. I would guess it would have a different part number due to some slightly different hole etc, but I bet either would work for either application with minor modifications. (2500 to Power Wagon). IE, I am sure a Cummins, G56, etc would be a bolt in, except for anything obvious (cutting the floorpan for the transmission shifter, winch interferes with intercooler).
Just a pure guess, but the economics wouldn't work for Daimler if they had to do a create new frame.
2016 Power Wagon; White Knuckle sliders, 315 BFGs, BD 2Lo Kit, AEV ProCal, Airbags/Daystars
Re: Frames
Post by olyelr » Sun Mar 19, 2017 9:49 am
And, what would be the point of creating a new/different frame? They would essentially end up being the same in the end.
Re: Frames
Post by DamageWagon » Sun Mar 19, 2017 10:12 am
They are the same frame. You are correct, the only differences are maybe a few holes and skid plate mounts.
Sent from my safe space
MikeKey
Re: Frames
Post by MikeKey » Sun Mar 19, 2017 1:24 pm
I thought I read on this very site that it was the same, but had additional re-enforcement.
Re: Frames
Post by Low_Sky » Sun Mar 19, 2017 3:28 pm
A few different holes and weldments, but I'm sure the structural members are the same as for a normal Hemi or Cummins 2500 crew 6'4" box. For example, the front track bar frame side mount is different, and that is a weldment.
2015 PW Laramie w/RamBox, 35"x12.50r17 Toyo C/Ts, custom rock sliders, PCP front/rear half-spiders, DOR steering brace, drinks Amsoil Kool-Aid, custom offroad pinstripes and extreme mud splash graphics
Re: Frames
Post by Reloaderguy » Sun Mar 19, 2017 3:55 pm
It's a half ton frame, that's why the capacity is so low.
Re: Frames
Post by olyelr » Sun Mar 19, 2017 5:13 pm
Re: Frames
Post by nts007 » Sun Mar 19, 2017 5:29 pm
Frame was identical to the 2500 in all the 3rd gens. Had different part numbers for mounting points for additional protection and accessories. I have one in my yard here.
Re: Frames
Post by RustyPW » Sun Mar 19, 2017 7:16 pm
nts007 wrote:Frame was identical to the 2500 in all the 3rd gens. Had different part numbers for mounting points for additional protection and accessories. I have one in my yard here.
2X
Russ NRA Benefactor Member
Re: Frames
Post by adeluca73 » Mon Mar 20, 2017 7:45 am
It's a 2500HD base frame.
Re: Frames
Post by Bill2014 » Mon Mar 20, 2017 7:57 am
This is one of the pictures I took of the 2014 PW frame sticker when the truck was brand new...Image
Locker Bypass
Re: Frames
Post by TwinStick » Mon Mar 20, 2017 10:52 am
They are the same for all intents & purposes. But they used to have different part #'s technically speaking. Not sure on the 2017's. Like the others have said, same frame, just some added/different holes for all the Power Wagon goodies. No big mystery here. :lol:
Re: Frames
Post by nts007 » Mon Mar 20, 2017 1:36 pm
Chrysler is to cheap to actually make a different Frame for the pw. But they want you to think they did :wink:
